Good old American DHTs, here matched up with French driver tubes (EL36) and Soviet 6SJ7s at the input.Are those light bulb resistive loads or vacuum tubes? Very bright. Looks like fun.
The amp can also use the higher mu version named TZ20 and, with some minor modifications, the funny looking 8025.
Veneered these today. They have been a long time in the making.
Dayton SD215A-88 + DS90-8 + ND25FW-4
The mid is in a dagger enclosure made from doubled up cones. I used caulk in between to try to get some CLD. Tomorrow will start on finishing.
Looks solid!Veneered these today. They have been a long time in the making.
I built my SET Tube amp myself with three large Edcor Transformers, based on Tubelab's SSE. Love it.Oh, it's compact and lightweight compared to some of the other amps I have. Things went out of hand a bit when the missus moved out a few years ago 😀
It's my design. I'll probably post a write-up on them once I'm finished with them. They're still a work I progress, but they seem pretty promising!nice looking speaker box. Was it your original idea, a kit, or did you copy another design. Interested in the design parameters, dimensions driver spacing's, etc.
MM
I slapped together two crossovers for some speakers I built a while ago (previous post).
Had them playing background music for most of the afternoon today. They are a little boomy compared to my OB main speakers, but sound great for haphazard futzing. Working title for the design is Beveldere.
Follow up. Playing with a REAL amplifier. The Boo OS build expertly designed by @schultzsch. I've named it 'Boule.' Source is my iPad with volume control provided by a DCB1. Just enough oomph for nighttime listening.
Looking good.
To make the bass less boomy on my bookshelf speakers (when placed near the back wall) I filled the br ports with some sponges which decreased considerably the output at 40hz.
Will have to try the boo(with lu) again on the new speakers.
How did you adjust the lu vds? I mean at what value did you set it?
Nice work! Those cabinets look familiar! 🙂I slapped together two crossovers for some speakers I built a while ago (previous post).
Had them playing background music for most of the afternoon today. They are a little boomy compared to my OB main speakers, but sound great for haphazard futzing. Working title for the design is Beveldere.![]()
What woofers did you end up using?
I didn't.How did you adjust the lu vds?
SB16PFCR25-8 are installed now. I also have some Sliver Flute W17RC38-08 to try. Probably in a second pair of those cabinets with a different tweeter, and ported instead of passive radiator...What woofers did you end up using?
right channel monoblock finished, finally 😀
Left channel will follow this weekend, hopefully.
In case anyone needs RTR speaker solid state relays. I am starting another batch of production but will need 15 pairs of pre-orders to proceed. If you are part of the pre-order, you get the SSR's at a discounted price of $100/pair vs $125/pair regular price. The interest list signup is here:
We have about 7 pairs of interest so far.
These are really hady to have around for your amp projects as they are small and unobtrusive and can be installed almost anywhere. They can even be installed inside a speaker but then will require a small 50mA 12vdc psu (like a small wall wart).
Ok, let us start an official interest list. Once we have 15 pairs of interest, I will ask you guys to place a pre-order and I can get production started again.
Pricing will be discouted to $100 per pair for folks doing pre-orders and then $125 per pair for those who do not preorder.
NAME / Qnty (pairs)
chermann / 3
birdbox / 3 to 5?
rusellc / 1
We are at 7 possibly 9 pairs so far. Need to get to 15 pairs.
NAME / Qnty (pairs)
chermann / 3
birdbox / 3 to 5?
rusellc / 1
On the bench last night was a new 6.5in coax speaker crossover development.
The new crossover is sounding pretty great. The transients are crisp as the step response is a right triangle. This, coupled with coax point source means the imaging will be fantastic.
Easy to drive impedance.
Step response:
Pretty nice bass too. The highs are from a small horn loaded compression driver (with a phase plug).
Step response:
Parts just arrived for Nelson Pass Full Range Equalizer. I'm going to put it inside my PeeCeeBee build.
