QUAD 909 Clone
Update on Gerber files
The error message relates to the polygons used in Eagle to create connections for the positive and negative supply rails and for ground. Their absence renders the rest of the board files useless. Time to learn a bit about Eagle, I suppose!
Ah, missed that bit. Cheers. Presume this is how it connects on the amp board. (using the same wiring colours as before. Red to J3, Black to J4 and Green to J6)
Where can i buy this quad pcb?
