Help troubleshooting M2 clone
I have 2 M2 clones built with Tea Bags boards. I connected the first M2 I built which had been sitting unpowered for about one year and noticed a greatly diminished output from the left channel. Both Q1 and Q2 are heating up but I did notice that Q1 is running about 10F lower in temperature than the right channel which produces the correct output. I poked around on the board looking for a bad solder joint with no luck. I replaced the problem M2 with a second M2 and confirmed the issue is isolated to the left channel board. Power supply voltages are fine. The only thing that changed was I did remove the fender washers compressing Q1 and Q2 to verify the FETs make and model. Is it possible I damaged one of the FETs doing this? Any help isolating the problem is appreciated. Both of my amps have operated flawlessly since I built a few years ago.
Jim
pic of left channel board causing problems
Were they working properly before they sat around for a year? I once had a bad Edcor input transformer that created low output. Check all readings on the pins of the Edcor transformer carefully. Good versus questionable channel.
This may be the issue. I took 3 measurements and the winding between pins 2 and 3 are different on the problem channel. Measurements below.
Pins on new unused Edcor iron:
1-3 45 ohms
1-2 20 ohms
2-3 24 ohms
Pins on good channel (right) climbs to approximately same values as new Edcor
Pins on problem channel (left):
1-3 95 ohms
1-2 20 ohms
2-3 110 ohms
Other side of Edcor transformer pins 5,6,7 measure about the same for all 3 cases.
Now to see if I can unsolder the 8 pins to save the board and parts!
I also measured the voltage drop across R13 and R14. Both channels measured about 400 mV and voltages across R3 and R4 measured about 200 mV on both channels with 10k resistor on input and dummy load on outputs.
Advice?
Thanks for that advice sir. I put a 500 mV of a 1Khz sine wave signal on the input and got these results:
Right channel - good one
Output of auto-former (PIN 7) 2.63 Vac
Amp output - 2.49 Vac
Left channel - problem
Output of auto-former 239 mV AC
Amp output - 226 mV AC
I checked to make sure that I got the same voltage on the problem board at the input node and PIN 1 to make sure it's not a wire or solder joint issue.
So I'm getting the expected 5:1 step-up in voltage on the good auto-former but not on the problem channel. Looks like emuffler was correct!
I'm sorry but that measurement was the same on both channels and very close to the input voltage, so I did not report. (I measured at pin 1 of the auto-former which looks like the output of the buffer.) The difference was the ouput voltage of the auto-former.
Anyway, my amp is fixed. Took me an hour to replace the bad Edcor auto-former. The amp is sounding glorious once again!
Thank you for your help Zen Mod.
Jim
Awesome!!! Desoldering all those pins and getting it off the board (without damaging anything) was no fun I am sure? Been there done that!! Testament to teabags board quality!!! I have a set of his M2 clone and the store boards with input cards. Both sound great!!!
Reactions: Milkduds
Now that you've removed the faulty Edcor, do you see any obvious damage (eg. broken wire)?
Unfortunately, the auto-former took a beating removing so measurements after removal were meaningless. I do know that the primary winding on the bad channel measured about 2 times the correct resistance when tested on the board. I guess that explains why I could still hear music from the bad channel. I was not getting any voltage gain. Those Edcor's do look fragile with very small wire. It would be nice if they were mounted remotely.
