Salas SSLV1.3 UltraBiB shunt regulator
The stability problem with mine version could easily be the modified CSS part of the regulator.
In my implementation there are no source resistors for the 2SK880s. I use them only for simulation purposes (Idds).
I am tempted to try a diode (1N4148) in place of R9, once I figure out the reason for the instability.
I have a trial PCB at 3V3 on the bench, full smd for space saving.
Regarding 2SK880s, i am now testing it with 2mA Idss of the Y classification without source resistors
If I use the GR classification with a source resistor to reach the 2mA, in what will differ?
Morning.
I suspect my lack of knowledge prevents me from being assured that the things I do I do right 🙂
It is embarrassing but I ll give a go.
15 V from the psu. G,S pins shorted. Meter in ma range, I put one lead on the V+ and another on the drain- measurements bunched around 8-9ma.
Am I doing it right?
Reactions: Salas
Hi Salas,
Could you please share your thoughts about using wirewound non inductive vs metal film low noise resistors (paralleled for appropriate wattage) for the CCs R1 position.
I have used the Vishay MBB series in some of my 1.3 builds and wirewound Vishay RS in others. Not very sure which I prefer since my A/B experience is limited. I am presently building a set of 1.3 for use with the Soekris dam2941 and I thought that since its been almost six years since the 1.3 were introduced, your sonic experience might suggest a preference for one type over the other in a specific type of application.
Thank you. Nash
I forgot to order Rf so connected bench psu to C1 to test.
Target output is 5V so my 3296Y-1-502LF positive trimpot is fine but negative side is just above -5.22V and stops there.
Should I order a different trimpot or there is a way to adjust Rvv or similar to fine tune dc?
I repost in case it got lost between others
Regarding source resistor
Does it somehow serve like it works better in the linear region than in saturation?
