Another ‘Are there any drivers like this’ question. Creased metal cones?
Are there any metal cone drivers with a pressed pattern in them that would impart stiffness but allow for a lighter cone? It would be like putting creases in aluminum foil to make it stiffer. I imagine something like a spider web pattern or geometric shapes like a soccer (foot) ball. I remember tweeter compression drivers (JBL?) with hexagonal patterns stamped in them but nothing done in a larger scale. The creases could be very small to get a honeycomb effect or large to have a revelerator cut cone effect.
Yes, thiel audio cs3.7
More than 20 years ago I had Fostex speakers with wavy diffusers, they were good speakers, frequency range 0-10000 Hz, sensitivity 90 dB, ceramic diffuser and covered with wool, corrugation of complex intelligent shape and double centering washer, huge magnet, slightly larger than the diffuser .
The HF tweeter is also Fostex. I placed them in an oak cabinet with an acoustic labyrinth design.
That was a long time ago.
By the way, I remember Loewe TV with a warm feeling; it was a good TV at that time😍.
Actually I was thinking along the lines of the stamped SB65WBAC25 not the wavy bent diaphragms.
My idea was a stamped diaphragm that is stamped in a geometric or fractal pattern to reduce unwanted harmonics and strengthen the diaphragm.
So wavy ones are stamped ones.
The advantage of such diffusers is not only rigidity, which means maintaining their shape during operation, but also a real increase in the diffuser area.
Reactions: stv
I was thinking stamped, ka’chunk as opposed to pressed, tizzz-tink. 🤷 I guess there isn’t much of a distinction.
My idea is to press the cone in a way that reduces unwanted harmonics, not unlike the painted dots idea.
I think you're really talking about cone break-up resonances, rather than harmonic distortion?
Generally speaking, the SB NAC and CAC drivers have less in the way of pronounced break up peaks than most other hard cones. I guess that may be in part because of the pressed pattern.
I never said anything about harmonic distortion, but, yes the idea is to reduce unwanted resonances, harmonic or non-harmonic, by using a stamped organic or random pattern.
