Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Hi Guys,
Need your suggestion about Nutrik XLR MALE connector. I have a passive I/V stage that has the green barrel connector
What would be the best neutrik xlr MALE connector that would be easy to connect to the barrel connector.
Ian sells Neurik XLR connectors, NC3MAAH which are for PCB boards. I'm looking for one that is more suited for enclosures. There are so many options on Amazon and not sure which is good.
I'm working on shielding for transformers and power supplies, not quite ready yet.
whether it helps remains to be seen.
the clocks are also shielded and grounded.
maybe Mu Metal would have been better.
I have still reserved space for 2x uc conditioner 3.3 volts and 5 volts.
all in all the sound is perfect.
Reactions: Clausen
will this support utilizing USB HDD connections to full extent on RPi 5 as well?
I honestly don't know, I don't use the disk on the RPi5. But you can try.
This configuration (PSU_MAX_CURRENT=5000) telling the firmware that this is bench power supply and that it should not attempt USB-PD and assume that it is 5A capable.
I have no problems with Ian's power supplies (UcPure or PurePi+Ifi iPower X) with this setting. I even tested a LinearPi Dual 5V with a UcConditioner connected in parallel, and it worked great with this RPi5 setting.
You can do this configuration (PSU_MAX_CURRENT=5000) through the Raspberry Pi OS.
Reactions: VMRKarnati
@VMRKarnati - Please be patient, it is a complex thing and zabloc was so kind to write one up, share it with me on PM for testing if it can be reproduced easily step by step and works. If so, I am sure it will be published. But publishing something which does not 100% works or is 100% clear for unexperienced RPI users (like me), will lead to endless back and forward of dicussions..... which we try to avoid obviously
