I can’t disagree with that statement more adason…….it’s not a dispersion thing, it’s a summing of the drivers and this is where all the critical detail is either preserved or mashed together.……I may have a better window to the experience as I’m mostly listening critical in the nearfield and I gotta say, for all its shortcomings, the concentric/coax driver sums as close to perfect as I’ve ever experienced.Horizontal is important
Vertical is not
Yeah….I think AMT tweeter tech is going to eclipse domes very soon…….they just sound so much more composed.Center to center makes it rather pointless.
2" drivers plus the mounting frame
makes it same or worse than a 6.5"
might as well just use a aluminum
reference 5"
dome mid
allows a smaller tweeter/ higher crossover point.
be taking full advantage of that.
MTM being a udder waste of time.
Dual tweets/ dual mids in some photos shown.
Why? lol
Even at high spl
you will exceed the thermal rating
before linear excursion gets touched.
Because = highpass filter
the mid domes are so small.
Usually run into phase issues up top
for crossover design.
likely only reason to slightly setback
a tweeter is to fight against the crossover
design time.
Very very tight margin for phase up top.
and 4th order would get dream like vertical.
MTM just pure garbage
Domes sound marvelous.
Just one, and a small small tweet.
Untouchable vertical.
Sitting / standing...you know the actual listening positions
that get ignored
Be easier to fight with a ribbon / planar mid
those sound darn darn good. accurate
if vertical is gonna suffer
Why not just buy two pairs of this Swan[HiVi] HF 802 kit speaker with dome mids and stack one on top of the other [top one inverted].
Now they just need to build at least ONE AMT with good vertical off axis behaviour and I'm back in the AMT boat ...Yeah….I think AMT tweeter tech is going to eclipse domes very soon…….they just sound so much more composed.
Check John Dunlavy designs, also his early Duntech designs. You might find all your answers there.So 2” dome mids…….fabric……sound amazing but limited in their lower end response as it relates to power handling……..MAYBE 700hz on a good day with transient peaks. How would I get around it?…….well two of course! Now the problem becomes the C2C spacing……BUT is it really a problem up around 5khz with such wide dispersion driver?………..could a 19mm dome pull off the transition?……the SB Acoustics SB19 certainly has the power handling on paper
https://www.parts-express.com/Dayto...Fabric-Dome-Midrange-8-Ohm-285-022?quantity=1
the smooth response on these is uncanny
https://www.madisoundspeakerstore.c...oustics-sb19st-c000-4-3/4-dome-tweeter-4-ohm/
and just as smooth. I’ve used this tweet before and it’s a hidden gem……just as good as an OM1 IMO
The faceplates of the mids would need to be truncated to get them close as would the face of the tweeter……or mount the tweeter flange over the faceplates of the mids…..closer time alignment sacrificing some diffraction.
Yep…..for home theater and those who like to stand up and sit for listening, the limited vertical window of the AMT is a problem. My Aurum Cantus 2560 will give me a vertical window of about 12” at a listening distance of 10ft, but that’s about it. That was A LOT of $$$ to spend for a small window.……BUT I can say with confidence that when you’re in the spot, the AC AMT is the best tweeter I’ve ever heard.Now they just need to build at least ONE AMT with good vertical off axis behaviour and I'm back in the AMT boat ...
Going back to the first post
The late Speaker Dave tried it in the Snell XA (two small mids MTM in an expanding array). The challenge is finding capable mids and then mounting them without compromising the tweeter.
Sterophile review of SnellXA
All i am saying is that we evolved over hundreds of thousands years as hominids from our ancestors on the savanna plains of africa. We did not have much defense against predators except our hearing and seing. Horizontally positioned ears and eyes allow us to pinpoint where the sound is comming from. Either to run from predator or to hunt for pray. Up or down hearing was never that important.You don't have ceilings or floors in your room? Ever tried the difference a ceiling cloud does to a room?
Vertical IS important.
Therefore horizontal behaviour of speaker is extremely important for all the stereo cues.
Flat on oxis and well behaving off axis, that is constant or uniform directivity index for higher frequencies.
Vertical is less important since our ears (and eyes) are horizontally positioned. If it would be important, we would have developed ears vertically.
Could be...
But all those verically alligned Dunlavy wmtmw speakers had great following. Every d'appolito mtm has vertical issues, yet they are widely used.
non environment room
https://www.acousticfields.com/tom-hidley-non-environment-rooms/
Not my room. I went with a sloped ceiling. And i amlucky to hve a fairly large space.
YouTube videos trying to communicate what part of a hifi sounds like are not very useful or very good.
dave
Vertical is not
I don’t know. My ceiling (7-17’ over 24’) more or less disappears anfd it makes a huge difference.
dave
As long as its not coaxial, it will have vertical issue. Even bookshelf with midbass and tweeter will have vertical issue.
With the XO at 250 Hz, the 3 drivers are withing a quarter wavelength and the drivers are essentially coincident. They don’tmsuffer from the need for a tweeter delay as in (most) coaxes.
Entire vertical will be from the midTweeter. Woofers are out of the picture by the time the box radiation ceases being omnidirectional.
dave
dave
Because you do not use infinite slope crossovers, there is significant overlap below and above crossover, where vertical lobing happens.
- Two dome mids in an MTM arrangement……anyone tried it?
