How to drill 4 mm holes in 1 mm. Steel and avoid grates?
With a sharp drill bit, little by little. I'd start with a 2-2.5 mm pilot hole. Then probably 3.5 mm and 4.0 mm. Use cutting oil. The hole won't be 200% free of burrs, but it should be possible to get a relatively clean hole that way. The outside is easily de-burred. You can choose not to care about the inside.
Without a punch that's probably your best bet.
A piece of perforated sheet can serve as a drill guide if you need to drill many holes for ventilation.
Tom
Reactions: OSLO
Ventilation for the graphics card (I hope this is ok, even in this Audio forum ?).
The top could be removed and used as an accurate drilling template, but removing the steel grates on the inside was a nightmare.
PS. Hej Tom. Rart at høre fra dig igen. Mvh Ole
Reactions: tomchr
Oh, so the issue isn't that you can't poke holes in the chassis. The issue is that you get burrs when you do so?
An easy way to remove burrs is to use a countersink mounted in a drill press. Run the drill at the lowest speed and touch the inside of the holes to the counter sink. I show that trick here:
Tom
Reactions: OSLO and rayma
Tom
Yes, Thanks, I hate burrs/grates. I also worry if they loosen and cause shorts.
Do you have a trick to drill a C6 Power connector (Mickey Mouse) hole ? The 2 first are easy, but the mid 3rd hole is a pain.
Why not just buy a dedicated ventilated case for whatever this is for. Computer?
If you have to drill a bunch of holes, just deburr them. Get a Shaviv deburring tool like the center one in the attached pic.
jeff
Fair question, but no case I like.
I did use a deburring tool like the one to the right, and it was terribly bad. Countersink sounds better, but access inside is difficult.
If you're gonna drill: start with a 3mm (1/8") bit. Use cutting oil, 3-in-1, something. After making the first hole with a twist bit, get a Step Bit to make the larger holes. A twist bit will bend thin sheet metal as it goes in, don't use big twist bits on thin sheet metal. There are many deburring tools out there, for sheet metal I like to use a Countersink Bit, but not one with flutes, they chatter. Use one with a hole through it, like this:
This will give you the smoothest edge.
Try to practice a couple cuts on similar material, if possible. Go slow. Have fun!
w
yes, I like to use the step bit to deburr both sides, if I can get the drill in there. If not, I have a 3/4" countersink with the 1/4" hex shaft, and I use that with a 1/4" ratchet. ya just gotta push real hard against the hole while cranking. heh.
+1 for step drill bit.
I imagine the local big box hardware store should have step drill bits. I bought fairly cheap one a few years back.
4mm-11mm. It has been worth its weight in gold. Several thousand holes through 1-2mm steel sheet and it still cuts like butter.
Cannot recommend the investment enough.
P & N was the brand of mine. Cost about $20usd
Reactions: berndt and Ben Mah
