Some new buys Garage sale stuff
Joined 2007
I picked up a couple today. One pair is a home made set using cheap Jaycar drivers but the other set is some old Tandy
Optimus 5-B / # 40-2006
I hope they are the ones I want with the twin 16R tweeters doing the midrange and a singleton working up higher
Anybody here have any experience with them before I pull the drivers out and check the boxes. One thing tho; these are quite heavy and do appear to be both e=well constructed and in reasonable condition
Can't remember which model I had, but a few years ago had something similar (documented hereabouts), in which I only kept the woofer, replaced the tweeters with a full ranger & donated them to my daughter IIRC. The woofer was a good one, measured well. Cheers!
Anybody got a crossover diagram before I pull them apart?
Dave is it only the impedance which is different with the tweeters/ mids or do they measure differently?
Bass is quite good but they are a bit squawky at the top
The box is so well constructed it would be a shame not to use it. Most Radio Shack boxes I've seen or had in my shed are pretty "RS" but these are solid and well braced.
Fs on these woofers is a respectable 21Hz and they might go a little lower if ModPodged so I'm surprised they go so high and are used open. I've not used the 4R version of these drivers before Only the 16R versions in parallel Which was more common? The 16R / the 8R or the 4R??
Perhaps my arithmetic is off but running the components through a calculator last nite if the attenuation circuit was in front of the XO and not after it the combination of 1.4mH to ground and that 10uF cap gives a XO frequency of ~740hz not 1700
Now I usually do put the attenuation before any other components, if I swap the configuration around could I just swap out the 10uF cap [ if it actually needs swapping ] and use the plastic plate still?
Edit
I'll be gifting these so the XO doesn't need to be perfect; just better than it is now with the mids top end mixing with the tweeters output
Hmmm If I was going to do that why not these?
It would mean having to modify the box by filling all the holes and cutting out a new hole and finding a decent tweeter
