Does JFET Idss change with temperature?
It changes, but I'm not sure in what direction.
Thank you, Marcel. 👍
I'm pretty sure Idss increases with higher temperatures.
The reason for my question is as follows:
* I generally set the current passing through a jfet to be 70% of the Idss - as I understand this is well within the linear region of a jfet's operation. (I set the current by adjusting the Source resistor.)
* so if I have measured Idss (with my Peak Atlas DCA75) to be, say, 10ma ... I will set the Source resistor so that 7ma is passing through the jfet.
* but if I have measured Idss at, say, 18 deg C - then if the jfet is operating in a warmer climate ... Idss might increase to, say, 11ma?
* in which case, the 7ma passing through the jfet drops to only 64% of Idss - which is perhaps below the linear range?
* of course - if the increase in Idss at, say, 24 deg is only 10.1ma (up from 10ma at 18 deg) ... then that's not enough difference to cause a problem! 🙂
There is zero tempco for jfets.
Erno Borbely say that zero tempco is at Vgs=Vp+0,63V
j113 Idss decreasing with temperature.
J170bl idss mostly incresing with temperature.
So, there is no general rule, it depends from actual jfet Vp.
