What's possible with a modern 3" Midrange ... 3way Prototype
I have done indoor ground plane measurements of woofers. If the woofer is near the floor and the mic is on the floor, the effect of room modes is reduced. reduced by a lot actually.
When using STEPS, I find it helpful to smooth the fundamental before calculating the percent distortion. 1/3 or 1/2 octave smooths the response out quite a bit. Many people do not like STEPS because it is slow, but I am not bothered by this.
I’ve often wondered about this……say a 2x12” bass section with one fwd facing woofer and one firing down to the floor…..it would seem rational that less room modes would result compared to either single driver solution……i‘m assuming a .5 coil in between the woofers of course
In the light of discussion what is possible with 3 inch midranges...Joachim Gerhard made new speaker with two beryllium Bliesmas. Interesting that he chose ScanSpeak 6640 tweeter instead of Bliesma brothers...and only one bass unit...
That’s the way to do it……imaging at its finest! If only more folks would get on board with the narrow baffle…….interesting case here is actually no baffle required
Hi IamJF,
I do not understand how do you get so much noise on the top of 2nd harmonic after 20kHz if you have LOT of absorption. The noise on the top of the 3rd around 13-16 kHz may have the same origin... but what is it? May I ask for the time-domain IR?
We talk about frequencies of 40-60kHz here. There is a big membrane resonance at 50kHz and the mic is going down after 50k. It looks pretty calm for that. I don't think it's noise but simply out of the useful range for H2 measurements.
I would even question the meaning of H2 after 10kHz ... (technical it's maybe interesting)
Hello everyone, this is slightly moving away off topic so apologies, I have a PMC MB2S XBD project I've been working on for the last few years. I managed to build the cabs and I'm in the process of designing the crossover filters using the Hypex FA 503 amps. However I cannot seem to find the frequency crossover of the original MB2S XBD , I have all the driver specs but i am trying to get as close as posable to the PMC speakers crossover set up .Dose anyone know where I can pull this info from ? thanks again , all the best ,,
I dont sorry, but I wouldn't worry much about it. Just buy some cheap second hand 4 ways active xovers and play around with the frequencies. I would start at 300 not knowing the drivers. Sell xovers when done or keep them for future projects. Btw. Actually dbx and other crossovers are cheaper on AliExpress than second hand.
Nice build.
Cheers
Yes indeed. At crossover frequencies above 3k, it is relatively easy to achieve a CtC distance of 1.2x wavelength. A ratio between 1.1 and 1.4 helps with the power response, and 1.2 seems about optimum.
If a 125 mm frame mid and a 105 mm frame tweeter are mounted so close they are touching, the 1.2xwavelength crossover frequency is 3.6k. If they are spaced out with a 20 mm gap between them, the 1.2xWL frequency is 3k.
Reactions: YSDR
so i am looking for the original crossover frequency's for the PMC MB2s Xbd monitors .. As you can see my project is almost complete and i am programming the amp filters and it would be cool to find out the original crossover points .. all the best everyone ..
I wouldn't even bother. Based on the data I've seen on many PMC speakers, their filtering choices are often very poor to the point that I'd consider the results to show incompetence in driver integration.
Much, much better off measuring and develop your own filters, pretty easy if you're active, end result is likely better than anything PMC could come up around the time the speakers were made, and depending on what they're putting out today, might even be better than that.
That's a really cool project, cabs look great.
Reactions: Amami Life
Looks like a serious monitoring effort 😊.
Are they intended for listening while standing/walking around? My newbie eyes sees it as bottoms should be laid on their sides to get ear-height down to seated listening? -Well I've recently been introduced to the idea that placing above ear-height has benefits. I wonder if that takes tilting tops forward as opposed to the old fashioned backwards tilting speaker feets for low floorstanders. Did you verify 380 and 3,8k as original xo?
Cheers!
