100W Ultimate Fidelity Amplifier
Hy again.
here is the schematic..:
AA14 schematic
I guess nobody build this AA14. so my question regarding caps.
because of avoiding some bad influence because of wrong caps - maybe too big capacitance i kindly aks:
C6, C9 could be bigger if they fit in, Audi caps ...right?
C3, C7, C12, C13, are 22µF/25V minimum because of the rail...bigger ok?
Which would you choose?
thanks
chris
Hi
here are prasi´s excellent documents:
Question.
just 2,2µF for C13, C12 ? is for the rail voltage.
Why ?
it is 3,5 pitch and 8mm diameter...so a 100µF/35V can fit
anybody has tested this amp?
kr
chris
Hello Chris,
Those are decoupleing caps, you can have any value, say 47uF 50V might also fit there.
I dont visit too often here, so sorry for the late reply.
regards
prasi
You will need a 35-40 Vac (dual or center tap) transformer. Will get you about 50-55 Vdc and provide close to 100 watts at 8- ohm. If you are asking about 4-ohm load, then step down to a 30-35 Vac toroidal. You are currently getting about 45% efficiency from your PSU, may need to increase capacitance or most likely go to a 7-10A transformer for that current load.
I would look for the AX14 (2-pr BJTs) or the FH11/12 (2-pr mosfet) - with 3-ohm load you will need 2-pr, even with low voltage. Assuming 60% efficiency, the AX-14 should provide right at 50w, with the voltage drop of mosfets, the FH11/12 will likely provide closer to 40w at your 3-ohm load. I have built both and the mosfet has better low-end, but also a warmer midrange. IMO, I would go with the AX14 since there are proven easy to find PCBs and IMO easier to build and fault find if you have an issue. YMMV
