First of all, beautiful amp!
On my 2 Bottlehead 2A3 parafeed amps, the parafeed cap(C2) is 3.3uf. Why 30uf?
Have you thought of returning the TFA2004JR to the 2A3 cathode instead of ground?
If you return the the lower connection of the OPT to the cathode you minimize the audio frequency current loop and eliminate the cathode bias cap and the power supply cap from the audio loop.Have you thought of returning the TFA2004JR to the 2A3 cathode instead of ground?
3.3uF at 20Hz has a capacitive reactance of about 2500 Ohms (2411 Ohms).
If the output transformer primary is 2500 Ohms, the combination of the output transformer primary and 3.3uF cap will be -3dB at 20Hz
And, that is also -1dB at 40Hz.
Suppose the output transformer primary was 5000 Ohms, and the cap is 3.3 uF.
Then, it will be -3dB at 10Hz, and -1dB at 20Hz.
See how that works?
That is why somebody picked 30uF as the coupling cap, plenty big enough (even a bit too much, won't hurt), and probably he had a 30uF cap in his capacitor bin.
See how that works?
Thank you!First of all, beautiful amp!
This is the post by Paul Joppa that convinced me to go for it (15 years ago):On my 2 Bottlehead 2A3 parafeed amps, the parafeed cap(C2) is 3.3uf. Why 30uf?
"Posted by Paul Joppa (P) on February 6, 2009 at 18:41:15
In Reply to: Last call: FS-100 plate chokes posted by mqracing on February 6, 2009 at 08:18:55:
Just a thought for anyone interested ...
In my experience, a larger impedance plate load always makes for better sound in parafeed. I've tried, or at least listened to, a wide variety of chokes as well as current sources. I once built a preamp with switched plate loads of 20, 24, 40, or 48 henries, for example (using 6BL7s parafeed to B7-5K) plus a current source - believe me, every inductance increase was an improvement.
Extrapolating that experience, here's a really wild idea - get a pair of these gapped for 60mA and couple to a TFA-2004Ni with a 27uF capacitor. If you can afford the nickel core TFA (still the best sounding OPT I've ever heard), this choke is neither inappropriate nor unreasonably expensive. Feed it with a 2A3 running 275v at 55mA - cathode resistor 910 ohms - or if you're feeling flush, one of those 2.5v 300Bs at 300v, 60mA (same cathode resistor).
Of course the greatest benefit will be in the bass, so use this to drive some ginormous efficient speakers with killer bass.
I predict you will never hear sound as good with a 2A3."
In lieu of the the 27uF. I used a 30uF Continental polyprop in oil that had a good reputation (anecdotal) That I had bought years ago.
Yes. Will try it soon. I kept it off because John Broskie ridiculed it. But will try for myself. Probably this weekend.Have you thought of returning the TFA2004JR to the 2A3 cathode instead of ground?
Bas Horneman,
Thanks for the post.
I am sure you caught the "Yea, Sure" negative affirmation.
Regarding the electrolytic bypass cap that is across the self bias resistor in the schematic Post # 128 . . .
"Many argue that this arrangement is the purer path, as it no longer places the icky bypass capacitor in the signal path."
I caught the comment: "Yea, Sure". It means the statement is Un-True.
If it is "not in the signal path", that means it does not have any signal current. Really?
Start with the cap in the circuit, apply a 1kHz test tone at the input, and a load resistor across the output transformer secondary, and measure the
voltage across the load resistor.
Then remove the bypass cap, and re-measure the voltage across the load resistor.
If there is any difference in the two measured voltages, you need the bypass cap. Well it Does make a big difference.
The self bias resistor "takes" the DC quiescent current.
The bypass capacitor "takes" the signal current.
When you remove the bypass cap, the self bias resistor "takes" Both the quiescent DC current, and the signal current.
The plate impedance, rp, of a 2A3 is 800 Ohms. The 2A3 u = 4.2
With an un-bypassed 910 Ohm self bias resistor, the plate impedance is Increased by 910 Ohms x u = 3822 Ohms (Rk x u).
With that, the gain will go down, and the damping factor will go down.
Just my opinion, please prove me wrong, measure with, then without, the bypass cap.
I'm confused though. My post in 128 is not to say the bypass cap should be removed. But that Broskie vaguely seems to say that there is no benefit to connecting the ground of the output transformer to the cathode instead of ground.
I have one of my 2A3 parafeed amps wired to the cathode, the other to ground. Didn’t hear any real difference when I made the change.
Where I hear a real difference is with the driver….the Stereomour has a 3B7 driver. It is the one I listen to…more detail and deeper sound stage.
I will have to play with the parafeed cap…move up slowly towards 30uf and see how it changes.
I have a TFA 2004 JR that I plan to pair with a 10Y driver.
Somehow my 801a's that I have are sensitive like hell...I had to remove power transformer from the chassis. Kinda soured me to the 801a. Perhaps I should try it again now that I have a bit more experience.
I have a Bottlehead BeePre preamp that can use 300B or 6A3 in front and 100dB speakers.
The 3B7 has more gain than 10Y/801, but is more than loud enough for me. Can always add a SUT if needed.
I like it a lot. It’s regulated B+ with CCS on top and filament bias. The design allows the 6A3 to be a direct drop in and they are much cheaper than 300B’s. I added more outputs to go to subs and amps to drive outdoor speakers.
Then it seems that the power transformer problem was:
Either the power transformer's vibration which made one or more of the 801a's various tube elements vibrate
Or the power transformer's magnetic fields made the 801a's steel plate vibrate.
- Tubes / Valves
- Building parafeed EL84 DC 2A3 amp
