Parametric tone control Question
I've built the DSELF PREAMP v13.01and it works wonderful and now I have a smaller chassis that I'd like to fill. I was looking at this old design, it's actually a 4 band parametric. but I only need 2 bands. I did a bread board test and hooked it up to my Wolverine amp, it actually sounds very good, to my ears.
So before I send the Cad drawing to Fabrication, I was hoping someone here can take a look at the schematic to see if I made any blunders or anything else.
Yes Its old school but I have all the parts.
Thanks all.
Scott
The thing I'm worried about this design is the input impedance and the balance.
"Rod Elliott - ESP talks about (P-226) the input impedance is determined by R1, which can be up to 100k with a bipolar opamp (e.g. 4558, LM4562, etc.) or 1MΩ if you use a JFET input opamp (e.g. TL072, OPA2134, etc.)."
This has 27k for R1,2. Should these be increased to 1M?
And he also uses a 10k pot for balance in P-02.
Should I change the balance pot to 10k?
I'm not sure.
and like how it can add or subtract tones.
Your current schematics simulates roughly to this (RV3A and RV9A having mid values):
A shelving solution would give something like this:
...about shelving circuits?
There is not much to read actually (googling shelving vs peaking should provide enough links though) , take any amplifier's tone control circuit which has two (bass-treble) tone control buttons and start simulating from there.
Center frequencies may vary and the dynamics can be tuned by changing filter component values.
In short - band based equalizers produce "bumps and valleys" in frequency response, shelving tone control produces (usually) continuous flow.
Just for experimenting I once converted a 5 band equalizer to a 5 band set of shelving filters - it worked somehow but in real life turned out to be unuseable.
Final...
I ended using the bass/treble circuit from the Yamaha C-50. The First stage is from P-266 fig 3 and I set it to about 10dB of gain.
The stage after the tone circuit is from P-88 fig 2 and then to Volume/ bal and final stage from p-88 fig 4.
To handle any turn on/off noise, I built a circuit that keeps the Lt/Rt outputs across 100 ohm resistors to ground for about 4 second when unit is turned on.
The Yamaha also used this type of circuit for muting. There is about a +/- 10 dB boost/cut in the range of 100Hz-500Hz and 1kHz-5kHz.
It sounds very good and does not have any noise issues when turning pre-amp on or off. I have it connected to my Wolverine amplifier and it's dead quite to my ears, with the volume all the way down.
Scott
  • Printing Print Schematic.pdf
  • Printing Print.pdf
    Printing Print.pdf
Reactions: madis64
