Hi All.
I'm investigating the use of Nichicon DB Series Electrolytic Caps for a project to freshen up Loudspeaker Crossovers.
I understand that Nichicon is a Japanese Brand.
I'm trying to source Nichicon DB caps in 10mfd & 5 mfd ratings.
Initial search in EBay points me to ShenZhen China, where a couple of sellers offer Nichicon BP-P caps which they claim are DB series.
Firstly what are genuine Nichicon DB caps doing in China?
Then are these copies or does Nichicon manuf in China?
How do I protect myself against copies?
Are there good Nichicon GB sources in Australia or other reputable markets?
Same for Mundorf ECaps?
Same for Panasonic FM?
Nichicon BP-P caps
Perhaps you mean Nichicon's BP-S (Bi-Polarized Series), which includes the DB series capacitors?
https://www.hificollective.co.uk/sites/default/files/nich_db_gb_0.pdf
Variation can be confusing.
BP-P is how they've been advertised.
https://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p4432023.m570.l1313&_nkw=NICHICON+BP+P&_sacat=0
The first thing you did was to look for the capacitors on eBay…..Hi All.
Not on mouser.com or digikey.com or Newark.com or other Nichicon authorized retailers.
Just because Nichicon is a Japanese brand, that doesn’t mean the caps will be made in Japan.
Take a look at the data sheet for the correct name
The UDB was scheduled to be discontinued according to that attachment.
Indeed!
The 'Muse' BP from this ebay listing may be worth taking a chance on: https://www.ebay.com.au/itm/355390338347?itmmeta=01HQ9YNQYYYP7WM8WYZTGTG4FK&hash=item52beea352b:g:NuUAAOSwNQ1lqPth&itmprp=enc:AQAIAAAAwGeEkXpIKFPRI+2qpManTH0Tngh6S2WnycgqPjbArMl7A3yCNySlxqKARvKm0TLC66AcXTY1W9QGflHuiXpVp5MxBa8+dbmkvgDUBWCgyl6ehDpLrGzw1j5osr5uV4Kp8hScbWygXmrQH/m0WlQYXaQ6odOdiE9+tIyP5A1iHHmEw5q2gr3PpaYnOEppNx+TD65AY0Hi07doVV14fNRi1KTLjtq32kRuJhq2H24kCA7+jM54jPIlsT/ne3c1x0QvjQ==|tkp:Bk9SR8j_1r66Yw
You can compare the product with this reliable source: https://www.hificollective.co.uk/components/nichicon_es.html
Cliff might find the selection process on those sites confusing - I know I did!
https://au.mouser.com/c/passive-components/capacitors/
I found Mundorfs though @CliffR52!: https://www.soundlabsgroup.com.au/c/Mundorf-Bipolar-Audio-ECAP.html
No 5 uF unfortunately - you'd have to use 2 x 2.7 uF in parallel - would be getting pricey for your application in your other thread though.
Thanks AL.The first thing you did was to look for the capacitors on eBay…..
I'll broaden my search.
The initial issue with the UDB range is that they're only +-20% tolerance and both leads come out of their bottom surface, not from each end as would most xover caps have.
I noticed the The 'Muse' BP have both terminals at one end.Cliff might find the selection process on those sites confusing - I know I did!
They'd mount proud on the circuit board rather than lying on their side??
They seem to be more suited to an Amp or other device rather than xover.
Also +-20% Any thoughts?
I thought the OP is looking for Nichicon capacitors for crossover speakers, ES caps are NOT for crossovers.....The UDB was scheduled to be discontinued according to that attachment.
Indeed!
It's true that their potential use in crossovers is not specifically mentioned.
The ES series is described as "Bi-polarized 'nichicon MUSE' acoustic series. Suited for audio signal circuits."
They're only +-20% tolerance and both leads come out of their bottom surface
These are described as "radial" capacitors. Those you would prefer are described as "axial" capacitors.
I've had a good look around the OZ suppliers and axial bipolar electrolytic caps appear thin on the ground - apart from 4.7 uF ones from Jaycar.
https://www.jaycar.com.au/4-7uf-100v-electrolytic-crossover-capacitor/p/RY6904
In the other thread there was a link to an opinion that "The caps Nichicon calls crossover caps come in DB and GB version, marked as BP-S and BP-P."
See post #6: https://www.diyaudio.com/community/threads/nichicon-muse-bp-p-question.308040/#post-5084967
I found that JayCar also have the 10uf version.These are described as "radial" capacitors. Those you would prefer are described as "axial" capacitors.
https://www.jaycar.com.au/10uf-100v...Text=uF 100V Electrolytic Crossover Capacitor
JayCar cap at +-10% vs Dubelier cap at +-20%, would you say JayCars offerings are atleast similar if not better due to tighter tolerances?
- Design & Build
- Parts
- Nichicon DB series Electrolytics - copies vs original
