Tesla Coil in amplifier
You have something against "Class A", WD?
I have a Class A amp and a Class AB amp - both designed by the same guy (Hugh Dean).
The Class A amp sounds much better ... unfortunately, due to its heat output - it can only be my 'winter amp'! 🙁
A is fine.
Not so much for overbiased AB
which is what I figured it was and later noted
by other comments.
Playing around with A circuits is actually
fun and a bit of a twist.
Adding strange things to amps like " tesla coils "
even water cooling etc etc. Are always fun , somewhat
rebellious in a way . Stirs up peoples
emotions. Much like art can stir up emotions as well.
And take the amp for what it is regardless.
Fun thread, DIY guys likely not spending 70k on
a amplifier.
It´s actually shameful, being a dane, when these type of pruducts (and their price point) comes under some
qualified investigation.
If in doubt, take a look at their cables and the connected marketing lies/pseudobabble.
And Class-A it´s definitely NOT.
They can´t even spell, how their "tesla-coils" are made. According to their website, their coils are "wounded" (not wound).
I think, everybody that´s ever been hit by a car, know what wounded means 🤣
Those Audiophools, where money is not an issue, get fooled every time. I realy pity them.
Reactions: JMFahey
Their "anti-aerial resonance coils" are what proves them to be highly evolved snake oil producers. They are not even creative, they copied the "high end chips" you stick on the outside of anything to improve the performance.
If your customers are people that do not work for the money they spend, you can be quite succesfull with such "Danish technology for the stupid". You don't need to sell 50 well build amps to make a living, just selling one 70.000$ voodoo amp and you got the same profit. They can pay reviewers much more than any honest Entrepreneur. The usual "keep the test object" doesn't cost them a fraction of the 100 times overpriced retail. How much technical education do you expect from a drug lord, Communist party member or the like? Just look what gigantic criminal industry the internet has created. These people want to spend money for useless status symbols, the more, the better! Africa is loosing it's most iconic animals, just because such rich idiots want to powder their testicles with them.
Only a single connection to a coil? There's no way for it to conduct a current, since it looks open-circuit. At analog audio frequencies, there will be no antenna-like effects that could alter sound quality in any way. My pet boa sniffs at such goings-on. I agree with her; so do I.
Reactions: JMFahey
Aavik I-880:
Active zirconium cable anti aerial resonance Tesla coils: 4
Only four? Make it 42 and we'll talk.
Ansuz, which apparently is more of the same BS from the same BS company, sells a 3m power cable for only $65k and 2x3m speaker cable for $62k. Børresen, one of the ******** behind this, makes a set of speakers that retail for $540k. Throw in a Aavik streamer full of coils too at $71k and you're golden.
Hey guys. Interesting topic title.
About 8 or 9 years ago I already built an amplifier using inductance for compensation. Moreover, inductance is really used in audio amplifiers in input circuits. But there are some conditions for their use - for transistors this is a cascode circuit and the rating of this inductor I used is no more than 100 μH, and naturally it comes with a core. Making such an inductance without a core is certainly an attractive idea, but calling it a Tesla coil somehow never occurred to me, hmm...
The implementation of inductive compensation in the input circuit is very similar, to improve linearity, and the use of bidirectional winding means that this compensation is grounded to the GND from a low-resistance point. Not the best solution, but impressed by the no-compromise solution))).
Reactions: MarcelvdG
I once used an RLC circuit with hand-wound air-core inductors in the line level section of a preamplifier. It was always humming, due to inductors picking up hum from the EI power supply transformer.
Much more recently, I used an LC filter with air-gapped potcores for the reconstruction filter of a DAC with two toriodal supply transformers. I didn't hear any hum at all when I listened to the noise floor.
I think "will spoil S/N due to magnetic hum pickup" is a bit of an overstatement, but depending on the type of inductor, they certainly might pick up too much hum.
Reactions: Hennady Kovalsky
harmonic spectrum at a frequency of 1 kHz
at high frequencies, the spectrum distribution does not change due to the low quality factor of progressive frequency compensation; only the level changes due to a decrease in the depth of negative feedback.
