New Stasis front end
Greetings to my DIY brethren. I journeyed to the mountain top, my quest to obtain the sacred scrips illuminating the second coming of the Stasis front end. As I raised my staff in supplication, I was blinded by lightning and the voice of the mighty ZM rang out:
isn't it already in post #1 ?
:snail: :snail::snail::snail:
Are these boards available to buy ? I have a sick Stasis 2 with burnt boards
Either method to secure the 2K thermistor to each channels heat sink will work fine. Also the thermostat shown on the schematic as "T" is drawn as a NO contact but NP has confirmed this is actually a NC type thermostat which opens at a temp around 65 degC to 75 degC and is also attached to each heat sink.
The thermistor is labelled TH and not R24 by the way.
Reactions: 1 user
Back in the good old days, we used to embed thermistors in the heat sinks on thyristor stacks for variable speed drives for over temp protection if the large cooling fans failed. Simple - drill a hole in the HS about 10mm deep slightly larger than the thermistor body, fill the hole with heat sink compound ( known as goop around here) and push the thermistor into the hole. We used to hold it in place with a cable tie with the hole on the end which was screwed down next to the thermistor. We also used thermistors with insulated leads and we never had a problem with that method. That is how I have done it on my Stasis build and have mounted the Thermostat next to it on each channels heat sink. But the screw down type thermistors would be equally a s good.
Reactions: 1 user
ZM's Stasis boards are (mostly) populated aside from power transistors. The smd capacitors on the OS were OK so I am cautiously wading into the sea of `there be dragons' with the suggested 2SK2145s. These 5 legged critters are significantly more tricky.
I have yet to build the power supply but are there any tests one can do prior to actually connecting it to a power supply?
The tests I do while completing a pcb before powering the board up are to check the resistance of every resistor used, I check every transistor with a Peak DCA75 and once all components are stuffed, I double check all solder connections with a magnifier and clean the board of all resin etc before applying power.
Also check that any trimpots are set to the correct position at start following the build instructions or designers notes.
Reactions: 1 users
