Balance and bias voltage unstable
Did you clean that socket, tube pins, and the tone control pots?
Do that and try again.
That's a bit off, but the tone controls probably are not set to be flat.
The signal is not missing yet, so go on after cleaning the parts.
The scope is preferable to use, rather than the DVM, for signal tracing.
You are looking for presence or absence, rather than the exact magnitude of signals.
Please use the scope and not the DVM for the signal tracing.
Reactions: solderbrain
Quick update:
C2 output tubes (pin3) 5.04V but look at the scope
C1 output tubes (pin3) 5.4V but again look at the scope
Yea i am using a cheap Chinese probe, I am in the process of a move and packed away my good probes! 🙁
So okay, that resistor I put it in the right place but it didn't make a difference, long shot anyway.
So, I am looking at the output blocks on this amp and it is very weird, how they work. The c2 output is connected to a block that isnt actually connected to the outputs of the transformer. The C1 is however connected directly to them. Looks like the c2 outputs go from the block (which has the speaker terminals, back to the phase revers switch and balance check switches on the front panel and then back? but I am not seeing anything except a couple wires on the block that has the putputs, very odd! I have to look in the schematic to figure it out.
There we go, traced it back to the Reverse normal switch, if I select the reverse, then the signal shows up at the output!
Let me like you said, do a proper clean on the switches, look closer at the schematic on the wiring of this rev norm switch and then I think we will be able to put this to rest!!! unreal 😵
But that does not mean it's the switch.
That reverses the channels.
So actually that means the switch is ok.
But clean it anyway.
But still clean everything that has not yet been cleaned.
Otherwise it's a waste of time to look for problems, since we already know everything is dirty.
okay but if I have the switch in Norm, there is a channel 1 and no channel 2 signal, if I put the switch in Rev there are both channel 1 and channel 2.
