Balance and bias voltage unstable
I decided to put my 1kHz sine wave in to the aux, 150mV P-P and have followed it through to the Level control, the output of the level control seems to go to pin 2 of the 7247 tubes. I see the signal going into the wiper and can see c1 vary out but there is nothing coming out of the c2 level out. Will try and take it apart and clean, but unless I am simplifying it more than it should be, looks like that is the issue, at least for this one, haha.
Ok, pull the tube just after the level control and then recheck at the wiper/grid node,
with the control turned up half way.
If the control is at near minimum, some controls will mute in one channel before the other,
due to poor tracking.
Pulled it, put back, same scenario, about 118 mV ac into each side and then one side is about 300 mV out and the other side is 9mV out. That is one question, if I check my RCA inputs at the back where the signal comes in, I have 212 mV AC on each one. then I measure each one as it comes into the level control and I have like i said about 118mV AC, then the one output is almost double and more than each input at 300 mV AC!
Here are the measurements on the 7247s:
Channel 1
Pin 1, Plate 2: 101.9 vdc
Pin 2, Grid 2: 300 mvdc
Pin 3, Cath 2: 3.8 vdc
Pin 4, 5 (shorted), Heat 1,2: 13.3 vdc
Pin 6, Plate 1: 147.2 vdc
Pin 7: Grid 1: 0
Pin 8, Cathode 1: 1 vdc
Pin 9, Heat M: 13.3 vdc
Channel 2
Pin 1, Plate 2: 102.8 vdc
Pin 2, Grid 2: 9 mvdc
Pin 3, Cath 2: 3.7 vdc
Pin 6, Plate 1: 149.2 vdc
Pin 7: Grid 1: 0
Ok, the channel outputs are about 10% off. That's around 1dB tracking error. Not defective, just an old cheap control.
Now repeat with the tube in place. But measure only at the plates (HV present), not at the grids.
The grid is a virtual ground in this circuit, so it is not meaningful data.
