hi all - is it possible to add a pilot light to the deck - neutral is switched at the front - can i put it in-line with the neutral return wire please ps pilot is 240v incandescant bulb - i dont like the idea of using a led
sorry i meant normal uk voltage - so one wire to the switch (neutral) the other wire returns to live somewhere ?
Why would they put the switch on the neutral line? That's unsafe.sorry i meant normal uk voltage - so one wire to the switch (neutral) the other wire returns to live somewhere ?
Device, presumably OFF, is HOT everywhere.
That schematic hides more than it shows, please post it in full.
While you're in there, if necessary reverse the AC line wires so the switch breaks the hot lead.
was it ledExcellent.
The AR ES-1 had a neon pilot light, and caused some buzzing. I had to remove that.
lol - there is some craft paper - sort of shielding - but the spades are fully rubber coveredSome ARs used Kraft paper over the hot terminals.
- Analogue Source
- Acoustic Reasearch ARxb - add a pilot light
