ElArte, you may find this thread at audiokarma.org interesting.
That thread started great and finished upside down. LOL
A simple solution to preventing amps that do not tolerate not having speakers connected is...
Wait for it!.........................
Switch the amps while they are turned off! 🙄
Yes, some want "convenience" - AKA a fool-proof design, so that they can save brain cells and make a mistake.Of course, that makes sense. Still, I think most people interested in these things are looking for protection in the event of a brain fart.
Perhaps an APP will be invented for that affliction too.
People live by APPS these days... their whole world is under "APP control".
I’m afraid no app will ever stop me from brain farting.
That being said, a sturdy 4PDT switch and resistors across the +/- binding posts is the solution I am going for at this time.
I might build the box based on the Grayhill switches, but at $70 per switch + the other parts, that could be a $200 project before I know it.
I purchased a 4PDT heavy-duty switch from Parts Express and have no issues with it for years.
A couple of dollars, add in a plastic box, some binding posts... done deal.
The reason I built this speaker switcher utilize make-before-break switches with resistors is because the user want to A/B comparing two tube amps on one pair of speaker, and he don't want a resistor connected parallel to the speaker.
With this switcher, he didn't need to turn off the tube amps for switching.
I hope it makes sense.✌️
Hi, All.Add a resistor across the tube amp output is a good insurance to prevent damage if the speaker disconnected accidentally.
If my tube integrated has two taps - one for 8 ohm and one for 16 and I'm running the 8 ohm tap into a switch, can I put the resistors on the 16 ohm tap for protection? Or does it need to be on the wired connection?
Thanks!
From a large distance and peeked at this topic only diagonally, it is a solid no. Consult an electronic engineer for proper advice whatsoever.can I put the resistors on the 16 ohm tap for protection?
Here are uncountable examples why.
Yes, install the resistor across 0 to16 ohm tap is ok.can I put the resistors on the 16 ohm tap for protection? Or does it need to be on the wired connection?
Thanks!
- Design & Build
- Parts
- Looking for High Quality Selector to switch two amps to one pair speakers
