planet10-hifi miniOnken Plan-Set Subscriptions
HiFi Loudspeaker Design
The miniOnkens borrow the side vents from the Onken (in particualr one from Audax published in the late 70s), but the alignment is way different and the slot vents are purposely made with very high aspect ratios adding R to the vent part, and push the reflex more towards aperiodic. Further it turns out, if needed, they can be pushed even further opeb cel foam to push them even more aperiodic.
A traditional Onken has a low bass shelf alignment, but i am told more and more are doing max-flat alignments. There is nothing magic about the Onken except the side vents, something that dramatically stiffens the side walls. One can get some higher frequency resonances from the vent length (but that can be an issue with any box with a longish vent).
dave
Reactions: wchang
Greetings to anyone and especially to the Onken/Fonken Guru.
I'm trying to understand how these enclosures are performing.
Do they have any special "virtues" in comparison to "horns", transmission line enclosures, ...
Are a special type of Bass-reflex box or something else ?
Are an "Open-Baffle" box with a (kind of) "acoustic mirror" attached to the back opening, but "tuned" to a certain frequency ? All at the same frequency or every port to a different frequency but all of them closely tuned one to another ?
From the sketches I see that they don't have sound absorbing material inside (maybe I'm wrong) so the efficiency of this type of enclosure shall be rather higher. The cabinet is a "live" one or an "as-dead-as-possible" one?
Elias
Onken/Fonken
A bass reflex with vents running down the sides. Offically with low bass shelf tuning, but many ar enow doing max-flat, and miniOnkens push the high resistance idea, increasing vent aspect even further but also having vents down the size.
Official Onkens tend to large, miniOnkens tend to be small. Low bass shelf is intended to get bass extention from drivers that won’t do it flat, miniOnken only goes as low as it goes.
dave
  • Thank You
Reactions: Elias Zacharopoulos
Yes, the CHN works in the same boxes as the Alpair 5.2/3,
but i have recently started to add the slanted front boxes as in the ¨Fonken set.
Includes plans for helper woofers, both ones that act as stands and ones that are meant to be distributed. This is one of them: https://www.diyaudio.com/community/threads/silver-flute-w14-woofers.396686/
dave
The 10”.That is one i have not done, but the one i most want to play with personally. Puzzlekoat and a new XO at minimum.
I would love to do a miniOnken, i can specify one, but cannot draw it up properly,
As miniOnkens tend toward small, and there is room for tuning smaller boxes than optimum for decent response. The tyopical Tannoy box i have seen and heard try too hard to get bass extention (big boxes poorly tuned) and give up some fidelity to get it.
dave
