And use two in an Isobarik alignment and now you’re talking……and still well within budgetYeah, I have an idea of a no BS driver candidate for a sealed box.
https://www.parts-express.com/peerless-830667-8-paper-cone-sls-subwoofer--264-1102
In a well stuffed 1 ft^3 box you can count on F3/F6/F10 = 50,41, 32 Hz.
At 50 W, the excursion doesn't exceed Xmax(8,5 mm).
You can lower the Qtb with stuffing to reach the desired response if you start
with a high enough Qts number and this one surely is workable in that sense.
I thought Max SPL at a given frequency is a function of Vd, nothing more. That is, 2 x RS225-8 in parallel or 2 x RS225-4 in series will have the same Max SPL.If I'm is "he". Then I'm sorry if I did not make it clear, that I always aim for 2 woofers, so that would have been RS225-8.
Not only looks, but also baffle-step and overall SPL, is the reason.
Yes - that is true in theory. But as I understand it, the parallel coupling, would make better use of the voltage swing in a capable power amplifier - mine is.I thought Max SPL at a given frequency is a function of Vd, nothing more. That is, 2 x RS225-8 in parallel or 2 x RS225-4 in series will have the same Max SPL.
Also, I often read that 8ohm drivers in general behave better than 4hom versions - no firm proof of this, though.
All this might lead to small details overall - maybe none - sonically. But the responses I get around woofers, tells me we, that we're nitpicking already - right?
@digitalthor another one to look at is the Fountek FW222 - still available from various places and models well for closed box based on datasheet; not too expensive, looks quite modern with the grill, breakup well outside your intended range.
Damn.,... that was quite unexpected. It looks nice, cheaper than all the others, and only real "downside" is its low power handling.... but with 2, and no real low frequency exposure, I'll think it'll be just fine. It might even be "snappier" than the others with its lower mass. Needs 70 liters for two. Not unreasonable... even though around 15 liters more than something like the WO24. Tempting.... really is 🤔@digitalthor another one to look at is the Fountek FW222 - still available from various places and models well for closed box based on datasheet; not too expensive, looks quite modern with the grill, breakup well outside your intended range
This Seas looks nice too...but is the price worth it 🤔
https://doc.soundimports.nl/pdf/brands/Seas/U22REXP-SL/pdf_Seas_U22REXP-SL_1.pdf
With two drivers, I need just 43 liters, to get a F3 of 70Hz. Just shy of 20 grams of cone mass. Should be snappy and detailed.
There is no evidence that lighter / lower Mms drivers sound snappier or more detailed.Just shy of 20 grams of cone mass. Should be snappy and detailed.
Found another candidate! https://en.toutlehautparleur.com/speaker-sica-8h2cp-8-ohm-8-inch.html Demodulating ring, not insanely expensive, decent Xmax, pro driver power handling, linear in passband, not too expensive, models well closed box, rugged looks.
Ah @jerome69 mentioned it already
The Fontek WF222 really looks nice... but I can't find anyone using it, or testing it. I think I found a little bit on the older WF200..... but that seems to be a totally different driver.
The most comprehensive datasheet, still seem to be Wavecor WF223BD02. And the HTguide test, indicates, that this driver has the most smooth low distortion of all drivers present.
Anyone who knows why the Wavecor datasheet shows almost 300 ohms at resonance?
http://www.wavecor.com/html/wf223bd01_02.html
These might be of interest
Out of stock
https://www.soundimports.eu/en/hivi-m8n-1b.html
Same or slightly different?
https://www.soundimports.eu/en/hivi-m8n.html
There PC speaker set up was pretty cheap but as they perform rather well the price shot up.
Out of stock
Interesting, that they are proud of their "high-loss" surround, when all others pride themselves with "low-loss".....These might be of interest
Out of stock
I would definitely consider. If it wasn't for their specific claim of a "warm" sound. I most surely do not need warmer bass in my room or with most music. I'd much rather have a firm, detailed and "correct" bass.Give the Silver Flute W20RC38 a shot and prepare to be impressed.
Another thing....
When you look closer at the Fountek WF222 and the Wavecor WF223BD. I mean - look at the chassis/basket, magnet, shape.... Aren't they very closely related - besides the obvious color, cabinet sealant, sticker and cone/dome difference??
https://doc.soundimports.nl/pdf/brands/Fountek/FW222/FW222-data-sheet.pdf
https://www.parts-express.com/Wavec...ber-Cone-Mid-Woofer-8-Ohm-298-1214?quantity=1
HiFi snake oil. Maybe it's what damps the cone. On Visaton using there full data, only available in Boxsim I have noticed some oddities with al cones.that they are proud of their "high-loss" surround
Talking brand this one may interest you
https://www.visaton.de/sites/default/files/dd_product/W 200 S_9029_9030.pdf
Not sure the price is a parameter to take account too early. This driver has some qualities and is unique, the closest drivers I know with a similar cone are from SBA MFC or Audio Technology. The choice is huge with your specifications, not so huge when you have more constraints like use in a two ways. This driver is a good candidate.This Seas looks nice too...but is the price worth it 🤔
You should make a table with parameters to make your final choice ?
The reason it all started. Was that I already play with 2x 8" SB23NRX in a closed box of 60 liters. The sound is ok. But the flange of the SB NRX series, is rather big, and I still believe the motor could be better - maybe giving a bit more sonic detail. So I started researching the hell out it....sometimes more or less successful 😆Not sure the price is a parameter to take account too early. This driver has some qualities and is unique, the closest drivers I know with a similar cone are from SBA MFC or Audio Technology. The choice is huge with your specifications, not so huge when you have more constraints like use in a two ways. This driver is a good candidate.
Oh... just zoomed in.. the Fountek is dark grey - not black 🤔
So, for 2 x 8-9" woofers, F3 at 50Hz, clean to min 500Hz in a closed box, and most detailed and correct possible sound, nice even/smooth look, that would match something like a black KEF Coax - and technically and sonically better than the SB23NRX.
Purifi, Excel, Texteme, Revelator, Ellipticor and the likes... that is simply too much money - IMO. Around 200 Euro a piece, would be around the max.
Let me also switch it around. What are the inherent drawback of the following drivers?
Wavecor WF223BD02
RS225-8
SB WO24P-8
And other drivers - if someone has specific drivers in mind - so that they can be sorted - and choices narrowed down.
By the way. Thanks to all for their patience and knowledge 😊 I definitely hope that this also help others, to collect this information - smoothing out some myths too 🤞
This Punktkilde shares the same basket as well.Another thing....
View attachment 1257189View attachment 1257190
https://www.punktkilde.com/augwl0020-jn03#product-menu
108Eut at Soundimports, looks good in 35l BR.
Good find 👍 Sadly only 4 ohm and I want closed box.This Punktkilde shares the same basket as well.
- Best 8 inch woofer?
