Also interesting, it appears that my login on homecinema.fr has been deleted or deactivated? I sent an email to the forum admin asking about it.
The email I sent to the stated admin email address (webmaster@homecinema-fr.com) bounced.
Also, it appears that I am getting the issue that PaulM reported back in 2020 of the volume control operating backwards. Fully cw it goes to -101.5 dB; fully ccw it goes to +10 dB or thereabouts. I never saw the resolution to this problem in the forum threads.
https://www.diyaudio.com/community/threads/ugs-muse-preamp-gb.277355/post-6360812
The solution is in the preamp menu.I never saw the resolution to this problem in the forum threads.
Menu > other settings > encoder settings > rotation
Hi Alex,
Yes, access to the AI document repository could be helpful if it isn't too much effort on your part.
Getting there with this, should be able to test functionality next week. Built both UGS cards, and they both came up with no issue. Checked a couple of things from the troubleshooting guide, but no issues.
Chris
Chris
I made one in the past but I am not sure if it is updated with the latest implementation. I can send it to you.Ahh, thanks! I hadn't been thru the menus completely yet. Is there any documentation for the menu structure? The only document I have seen was for v.003 from June 2016.
Ok let me contact you by PM on this.Hi Alex,
Chris
Got around to firing this up and testing it. No issues. Ran RMAA on it, looked pretty good. Put it into my main system this afternoon and it sounded good. It will take awhile to decide whether this will replace my Pass Aleph P or not, but it is nice. It will also be awhile before I get around to casing it up, so it won't stay in the main system at this time since it is just on a couple of boards.
- UGS-muse preamp GB
