Pass F5m
This is a really good illustration of the importance of a proper grounding scheme.
I have been watching the store and waiting for the kit to show up. I already have a couple pairs of Meanwell chassis mount SMPS. My inclination would be to follow this scheme and add bulk storage capacitance for each channel - 15,000 uF to 30,000 uF on each rail.
I tested two RC filters different connected either SMPS->RCfilter->F5mPCB or SMPS->StoreFilter->RCfilter->F5mPCB.
The RC filters were 0R22 and 22mF and 0R25 and 3.3mF. The filters didn't reduce the 60Hz harmonics enough to be worth the space and added PS impedance.
The Mean Well supplies and the careful star ground implementation are responsible for 60Hz harmonics being low. Also the F5m amplifier topology has a good PSRR. The store filters don't do much below about 4kHz as shown in this Bode plot.
Reactions: Georg Kovalcik
The inherent noise floor of my spectral measuring system is limited by characteristics of the M-Audio AP192 sound card and the external "wiring" to the deviced being measured.
This image shows the loopback spectrum of the soundcard with wiring analogous to that when measuring the F5m. The rising noise level starting at about 40kHz is due to the noise shaping of the DAC and ADC in the AP192. This needs to be taken into account when evaluating the spectral measurements of the amplifier shown in the previous posts. As can be seen, the noise levels from the amplifier are near the underlying noise floor of the measurement system, with the exception of a few low level harmonics of 60Hz (around 25uV rms) and some low amplitude SMPS noise at around 40kHz-60kHz,
Reactions: dBel84 and A Jedi
By careful implementation of the star ground topology shown in the second image, the noise levels were well below 100uV rms.
Bottom line: These Mean Well supplies should present no significant noise issues, particularly when good grounding practices are used.
Hello Ihquam,
Nice post, very interesting.
These Mean Well power supplies (I bought two LRS-150-24) have small ceramic capacitors between the negative output and ground. Mine has two ceramic capacitors in this position. My question is if you think these small ceramic capacitors can create problems, like high frequency ground loops or something? (and thus better to be removed in case +/-24V with center " tap").
@TungstenAudio or anyone else who can help with my education...
Why would adding capacitors help here?
As noted previously I used a local capacitor reservoir however, upon reflection I'm not sure it helps.
It's possible that some/many/most linear supplies are undersized and that adding a large charge reservoir provides a temporary support to reduce the amount the rails droop as the result of a large transient current draw. Also, given the low frequency of the charging pulses some filtering is likely needed to remove the line frequency and harmonic noise that could creep through.
The `ripple and noise' from the SMPS is quite low and the oscillations in the rail voltage are way above the audio range. So, IF the SMPS can meet all the potential loads in a steady state condition then perhaps a charge reservoir is unnecessary. Also, one could perhaps argue that adding anything between the output of the SMPS and the amplifier board that could hinder the current delivery (like a CapMX), might not be a good thing. I don't know. I do not mean to be argumentative, but I do want to know.
