Rogers LS3/5a
Really?
The story I got from family was that they were over doped in production, an error in consistency that Goodmans were...ahem unfortunately known for back in the 70s
This period is when my late father worked in the R and D, on car audio - which Goodmans benefitted from greatly, under the BBC contract (they were able to pinch ideas from the driver and design, without breaching copyrights)
Lastly, I tend to believe what I was told by my dad, his family and work friends from Goodmans- in favour of anything written by RMAF on a different continent, more than 50 years later.
(I'm fairly certain anyone directly involve with the project, at least at Goodmans, has passed already, like my father)
As I’ve oft opined the LS3/5a’s suffer from several what I would call major flaws, but midrange coloration is not one of them. The primary problem for the LS3/5a’s is that the crossover is the size of a small amplifier, that‘s why they’re SO inefficient. In fact, I once removed the crossover package from my Rogers and replaced it with a simple 6 db/octave crossover to see how it would sound. The modified speakers were more dynamic but less engaging than the stock version. I also ran them with two count ‘em! Janus subs with phase control, and at least I had bass, but the midrange suffered. Oh, well, sometimes magic overrides logic. I moved on to Quad 57s and then to Fulton Nuance floor-standers.
This totally.
The crossover, though necessary to cleanup the issues of the driver, mostly B110 issues, sucks so much power it is maddening.
I respect Scootmoose and his opinion usually, but not here.
Yes these were designed for vans, mobile studios and for near field vocal monitoring, at modest levels.
At this they still excel, but time moves on nd what they can do, many can do better today.
Used in studio at Radio1, 2, 3, 4 as they were for many years, perched in free space ok top the console, they worked perfectly for the application, and they didn't have to handle bass.
Used right in a corner the bass was a little humped, well actually too much, but for male voice intelligibility it worked.
Used in the home for hifi, they work too - but they don't do parties, heavy metal, or anything over about 90dB without wheezing, and sounding chesty and boxy.
For MUSAK, played at low SPL, they are brilliant - but many would just use PC speakers now and not really notice or care for the differences.
For all my love for the LS3, they have limited uses in hifi, unless you don't mind them being very SPL limited.
Really?
Does not necessarily contradict the dislocation finding. Over-doping could have led to easier separation with prolonged use due to more coating mass bouncing on that mechanically critical meeting point.
Reactions: Scottmoose
Yes and no. They're inefficient a/ because the drivers are relatively small, low-Vas, low Fs units, so their inherent sensitivity isn't great: about 87dB, give or take, under IB conditions, and b/ because once you stick that into a very small sealed box with all the diffraction &c. issues to contend with, the EQ needed clobbers even more of that. It didn't help that they went for a 15ohm nominal either for the first generation (albeit for good reasons), so they pull little current but need significantly more power than a more typical 8ohm model; as a result lower power transistor amps can run out of steam quite quickly -not that they can get especially loud anyway since power-handling itself is limited. The later 11ohm models were a bit easier to drive in that sense. With just a nominal 6dB filter (I assume a cap & coil) they'll be an easier load for a lot of amps providing there isn't too much spread between the HP & LP electrical corners, so should sound a bit more lively, but without the EQ the filter provides, the response will be all over the place. Shades of the Kan...
Quite likely; I've seen that happen a few times. A (now departed, so may he rest in peace) chap over here who deliberately courted controversy at every opportunity took to pouring large quantities of contact cement over cheap drivers & advising others to do the same; I've seen a couple modified in this way that came apart at the neck & surround due to the excess mass.
Reactions: Salas
Absolutely convincing on voices when used as such. It happened I listened to a pair perched exactly like that in a big radio station's studio in the early 90s. Was Rogers with XLR input terminal. During a comedian's show mocking voices of politicians and sportscasters. He was alternating between live and reel to reel prepared sketches. I could hear him live and recorded sitting next to him behind the console.
Just to clarify, here are original specs,
CHARTWELL LS3/5A SPECS
Frequency Response:80 – 20,000Hz
Sensitivity:82.5dB (1W input, measured at 1m)
Impedance:15Ω
Power Capacity:25W (continuous program)
High Frequency Driver:T27 SP1032 19mm (0.75″) Mylar Dome
Low Frequency Driver:B110 SP1003 110mm (4.5″) Bextrene Diaphragm
Crossover Frequencies:3,000Hz
Enclosure Type:Closed
Enclosure Dimensions (HxWxD):300x190x160mm (12×7.5×6.25″)
Weight:5.5kg (each speaker)
And there you have it. You start off with an 8ohm, mid-Q, low Vas, low Fs (for size) midbass with a nominal IB output of about 87dB @1m, and once you've dropped it into a shoebox and added all the EQ necessary to correct for the diffraction etc., & shape the response to the desired target, you've kissed about 4dB - 6dB of that goodbye. That's just what happens with that combination unfortunately -and when you couple it to fairly limited power-handling & a raised nominal impedance, you've got yourself a (for typical transisitor amplifiers) low-sensitivity speaker that's also rather difficult to drive, and can't get especially loud even if you do have large amounts of power on-tap.
It was a good speaker of its type, and for its intended purpose. And to a point it still is, although it's possible to do better these days. But it was never designed for home audio / hi-fi, so it's not surprising that when people use it that way, it tends to polarise opinions.
For those tube amps with 16Ω output terminals also or a switch the output power spec doesn't change. I listened to the LS3/5a Rogers 15Ω reissue with a 30W Leben CS600X recently and it was a loud enough and quite entertaining combo.
Speaking for myself I am surprised by the polarising opinions when it comes to use as mains in a room for listening to music. They might be nice dinky little things but they aren't high fidelity speakers and I would have expected this to be obvious. I am also fairly sure that for the first few years of their life in the UK they were considered to be good computer/desktop monitors (which they were) rather than awesome magical main speakers for use in rooms. This seems to have been created a few years later by audiophile enthusiasm/marketing/reviews. Something similar happened with the Linn LP12 turntable. How those magical properties have survived over the decades and possibly even grown is even more remarkable/baffling.
Would anyone in a blind test that included LS3/5As and examples of high fidelity speakers rate them as good? Or have I lost the plot?
And was it just a matter of time before some employed classic misdirection/trolling rather addressing what was posted? Can we take your presence here as an indication that you consider LS3/5A enthusiasts to be potential customers for your products?
