Point Of Damping
I've been working on a set of speakers for a bit. Finally settled on the drivers, amp, etc. I was reading up on dampening materials and I'm a little lost. Are you just trying to make the inside of the enclosure an anechoic chamber? Or is it more about attenuation specific frequencies? Also, would lining the inside change the functional behavior of a PR?
Different kinds of boxes require different approaches to damping.
The end goal is to help minimize internal reflections from coming back thru the cone.
A sealed box is usually filled with something like poly fluff, reflex enclosures (ie with a PR) are usually just lined as the damping will reduce the affect of the helmholz resonator.
dave
Cabinet walls might also need damping to reduce vibration. It is achived by some damping material similar to what is used for cars. Bitumen sheets or bitumenous felt IIRC. There might be more modern materials today, similar to Blu-Tac. Vibrating walls could color the sound by boosting some frequencies.
Some of us use the click test to decide how much lining or stuffing is 'just enough'. Normally for damping vents, but works just as well on sealed or if using proper measurement gear, then an impulse response can dial it in to technical perfection.
Use enough, but no more than necessary.
How somebody know what is enough but no more?
I haven't took a definite answer when i had measured mine Asathor.
I have used ARTA for impedance measurement.
What is better stuffing,yellow or green?
Second picture is a free to air woofer measurement
In a closed box it is OK to stuff the whole box, just to be sure. It isn't really necessary to go that far to manage modes, just a portion of each dimension will do. Also, when subs are used it is usually preferred to combine them with closed box mains.
Ported boxes are no different, but when we are trying to get more bass by going ported, it simply seems a shame to waste it.
Luckily, the damping material works better at higher bass frequencies where the modes are found, and not as well at the vent frequencies.
