Link, please.I just found this new tpa3255 board
Does anyone here have experience with this smps?
https://www.ebay.com/itm/3550825070...486&ssuid=&var=&widget_ver=artemis&media=COPY
Joined 2018
I bought this TPA3255 Board.
Four capacitors beside heatsink are series-connected 4700uF/25V.
So a total of 4350uF capacitance is embedded.
It's not a good idea from the point of view ESR.
By the way, another complaint...
The speaker output makes a pop noise during Power-up and Power-down. So I developed an automatic reset control circuit.
This can eliminate pop sound without manual reset switch control operations.
Hope this will help you easier.
CyberPIt
CyberPIt
That looks surprisingly identical with this:
https://www.parts-express.com/Dayto...rd-with-Tone-and-Volume-Co-325-501?quantity=1
You don’t want to use a 150W class D for a headphone amp. There will be some residual Class D switching noise (beat frequency from 400kHz and other sources) you might hear, and in event of a pop from turn on/off or when accidentally hot plugging a jack, it will blow your headphones in an instant.
You want Class A and 1W or so for a headphone amp.
- Class D
- TPA3255 - all about DIY, Discussion, Design etc
