Suggestion BR Cabinet for TangBand W4-1337SDF
Hi friends,
Couple of weeks ago I bought this nice looking TB drivers.
My plan is to put them into a simple BR cabinet.
I Also like to reuse my old Stands that I kept from an old project.
Here 11,5 ltr Net.
Poort tuning 55Hz.
Anyone experience with this driver?
Hereby the first concept.
I don't think you can tune that driver that low, it will be a one not bass that runs out of xmax very fast (on low volume). The cabinet is also to large for a good tuning. Better use a smaller cabinet tuned higher like a 6L tuned to 70Hz. And if you need more bass, add a sub and cross higher (arround 90Hz at least).
Reactions: mordikai
They certainly are ugly alignments, the kind you see when people ar etrying to get more bass out of a driver than it is really capablke of. Quanity over quality.
The general rule i use is that the first derivative of the FR graph should not pass thru zero more than once.
dave
Hi Waxx this is the curve with 6 liter and BR tuning 70 Hz.
Not bad at all I think.
Here now 7 liter tuning 70 Hz.
I think the volume of the TL above is much bigger then 7 liter.
I calculate approx. 14 liter for that TL.....
I have. 😉 No plot posted above, but 3.9 litres to 70Hz isn't too bad if you're near boundaries, & assuming 1/2ohm series R for wire loop, connection resistance etc. Otherwise, 4.2litres to 74Hz isn't too bad either if you want a little less damping to the alignment. Limited power-handling in all cases of course, with the expected slight edge to the former, but inevitable given the driver size & limited travel.
Reactions: planet10 and GM
I'd need to know the dimensions / geometry of the line and the damping used -since you say you purchased the plans though, I assume they can't be distributed, so there's no way I can check its alignment without buying them myself. However, from a very quick look, it seems to be a fairly simple [near] end-loaded type; it's probably tuned below Fs, but I suspect it will be fairly well-damped.
Dear Scottmoose I can not share the details of the TL.
Hereby on real scale the BR vs TL.
BR = approx. 7 liter.
The TL has also a filter with 3 parts.
Edit: in the YT movies above you can see the building process and damping inside.
