Hello, I want to know what the advantages and disadvantages to combine 2 silk dome tweeters and two titanium tweeters would be.
It seems to take a while, but this is one way to mix speakers.
For those who don't understand what I mean, "mixing" means using titanium and silk dome tweeters simultaneously.
Op’s probably asking about soft domes in maybe the front mains and metal in the rear, or some other mixing, although he seems hell bent on not saying what exactly he’s talking about.
Come on brother, you can do it, ask an answerable question.
Ok now I know what brand of blender to buy lolIt seems to take a while, but this is one way to mix speakers.
I want to make some changes to my sound and I have two silk dome tweeters for each speaker in my system. Then I'm thinking about adding more two, but made of titanium.
One tweeter per speaker box generally speaking. Also, if you’re not well understood about crossover and speaker design I would suggest leaving them as they are.
I understand, about the problems of using too many tweeters.if you’re not well understood about crossover and speaker design
Call me by my username or my name, okay.Sorry uncle
I'd say a disadvantage would be if both types played the same part of the audio spectrum simultaneously. Comb filtering as was mentioned, because it's physically impossible to lay one over the top of the other; they have to be side by side, above / below and that finite distance between; comb filtering.
Now if you cross from silk to titanium at some frequency, then the problem goes away. That would be a 3-way, with just different frequency points for the cross than an ordinary w-m-t 3 way. Perhaps you can gain some advantage over running either the silk or titanium set alone, that could sell.
Metal infused composites can work better than one material alone. Newer commercial airplanes are made from carbon fiber and titanium strands to protect from damage due to lightning strikes. Lamborghini uses a mix called "carbo-tanium" for their chassis and even suspension parts, so you know its tuff stuff.
Supplementing a larger fabric dome tweeter with a smaller diameter metal alloy dome is something Harbeth has done with some success, but its hard to predict vertical dispersion behavior based on the acoustical environment its being used in. They even run both tweeters wide open. Some people like a rear facing tweeter supplementing the front in or out of phase. I'm not a fan of this as it affects coherence of soundstage and imaging in a euphonic way. It just sounds unnatural to me with acoustic music and vocal soloists.
Ok, since you’re so sensitive, I’ll quit trying to help you and leave the thread to the jokers. Cheers 🍻
- Mix of titanium and silk dome tweeters
