Subminiature tubes/valves for Hi-FI
@b_force
I tried, initially, to use a 7806 for the heaters but that thing got really, really hot. Then I had the idea of placing an external power transistor to help the regulator, but never got the balance between the two right. The problem is that, if I use a 12V power supply, I will have 6V drop across the 7806 and both valves are pulling 700mA or so. Finally, I gave up and used a buck, which runs cool. 😎
That doesn't surprise me if you were using a 12V power supply.
That is (12-6)*0.7=4.2W of power dissipation.
With a buck converter that is more around 630mW or so.
Reactions: pcardoso73
@b_force
By the way, after what you said regarding the 6021, I had a look to the curves and said holly crap, I really messed up.
Went to ebay again and the seller exchanged that one for a 6AK6. UUUuufff (he didn't have EL91/95).
I will try it, as you suggested, as a replacement for the 6P30B-R which consumes more than 400mA of current.
Reactions: b_force
My take on subminiature tube preamp. Differential, high gain, high current, low distortion. I'm also planning to use SMPS for the heaters one of these days, I already have the converters.
Reactions: Koifarm
