Sure! You just need to find C4, R4 & R5 on each board, that is where the modification is done.
-Jumper the LTP emitter resistors R4&5 (or replace with 1ohm resistors) change the compensation cap C4 to 5,6p or 6,8p. I prefer MICA, but NPO is ok too.
-Then you put a resistor and cap (I used poly cap) in series (C11/R35) and put them parallel with C4. This is the nested feedback. The values are a bit 'to taste' as I describe in post 5, 4 and 26. I used 0.68n & 860k. You could probably run some wires to the outside of the amp to play around with these values and listen to the result. The values do not effect the stability of the amp, just the amount and frequency response of the global feedback in the amp.
As mentioned earlier, I also adjusted bias and removed the muting circuit, but bias can be adjusted per manual to 30mV, and the muting circuit is not a significant change, I just wanted to do it 🙂
Allright this might be doable but for the bias I'm not so sure if I could handle that but thanks for the input much appreciated 🙂
Adjusting bias is easy, check the manual. Voltage at TP1 should be around 30mV after it has warmed up. You use VR1 to adjust.
Ok we will see otherwise I will contact you for this, as for bi-amping like some folks suggest on other forums what would you say about that?
I have never dealt with such things before and the more power the better the bass response etc.
I remember now that my Speaker 1 button/function suddenly stopped functioning 2 years ago so I use the speaker 2 since then, is there an easy fix for this?
Bi-amping can be good if you have a 'sweet-sounding' amp you want to use for mid/treble, and another amp that has good control for bass. High power is not always the same as good bass control IMO, high damping factor/low output impedance is more important for bass I think. Then there is also the matter of volume matching the amps, having a separate pre-amp so you can use the same volume control etc..
This mod should give you what you need in one amp.
I have no clue why one speaker output is dead. Could be button, relay or something else..
As long as this HK670 have the high damping factor and can manage low impedance I'd better stick to this instead of all the hassle w. bi-amping + the speakers RSIIIb are not originally made for this without internal mods/wiring, I never play music on very loud levels anyway***
I think it will be fine. You get higher damping factor in the bass with the mod, mid and treble is about the same as standard (depending on R35) as the original amp.
You could say the R35 resistor determines the sweetness vs detail in the mid/highs. Higher value = more detail, lower value=sweeter sound. The C11 capacitor value determines at what frequency the damping factor starts to increase, lower value, higher frequency. You should end up with values not too far from mine I think.
Just a little nice surprise here, tested the Speaker 1 terminals again and now they are working just fine ;-)
@ Rallyfinnen again, I might consider buying a Vincent SA-31 preamplifier with a Cambridge Azure 651w poweramp that delivers 100w @ 8 ohm and 150 w @ 4 ohm (for decent money) or is it no big difference vs the HK670 specwise would you say, except maybe some "obvious" refinements in soundstage + resolution?
I think you know more about the Cambridge amp than me 🙂
For me DIY is part of the fun, and to me it's more satisfying to improve something than to just buy something and use it. If you like the sound of the HK, and you have confidence to modify it, I think you should try modifying it.
I can also add that this mod also works on the HK980, which has the same power amp modules as the HK670.
I did the HK980 with 10ohm emitter resistors on the LTP(R6/R7), and 5.7p on the compensation cap C6. Sound is really good, and square wave is perfect. I think this could be a better combination.
I'm looking at doing this on a HK670, so just wanted to confirm in summary:
Change R6/R7 from 180 ohm to 10 ohm, 1% 1/4W
Change C6 from 3 pF to 5.6 pF, 5% 50V
Add series 860k 1% 1/4W and 680 pF 5% 50V in parallel with C6.
The diagram and part numbers is a little different from what you had in your original post, so I'm going off the attached diagram.
Also - is Ceramic 50V ok for the capacitors? Using Mica and 500V is a lot more expensive.
Yes!
C6: NPO is ok, but if you want to do it the 'high end way' its not that much money for two Mica's.
For the 680p I used some poly cap (MKS I think), not sure mica is of any benefit here.
50V caps is ok, but more margin would not hurt.
From my supplier:
@ 680PF the Mica's are $10 ea or a minimum order of 10 units for Foil. There's a 680PF axial general purpose film one I could try?
other Mica's are only available @4.7PF, 5PF or 6.8PF...what value would be best? I'm using an 820k resistor as they don't have 860k either.
Just wanted to check this. The manual I have for the HK670 (amp from ~Y2K) does not mention bias settings, so I looked it up for the HK980 which is supposed to have the same amp boards. In that manual it says to set to 10-11mV. Thoughts?Adjusting bias is easy, check the manual. Voltage at TP1 should be around 30mV after it has warmed up. You use VR1 to adjust.
Might sound the same, worse or better. Hard to say. To really improve sound you should improve or change speakers.@ Rallyfinnen again, I might consider buying a Vincent SA-31 preamplifier with a Cambridge Azure 651w poweramp that delivers 100w @ 8 ohm and 150 w @ 4 ohm (for decent money) or is it no big difference vs the HK670 specwise would you say, except maybe some "obvious" refinements in soundstage + resolution?
No need to use mica for 680p, you can use a poly-cap for that, as I wrote before. For C6 it's safer to go with 6.8p.From my supplier:
Regarding bias, I think abt 30 is what I ended up with when I adjusted it while measuring distortion. You can set it according to manual, I don't think the diff is audible.
I have an HK670 power amp that is working well (not a receiver). Mains power is 240V. It's been in storage for 10 years in a sealed box.
If anyone wants it, I will send it along for the price of postage.
- HK670 integrated amp sim, mods etc
