I’m starting this thread in the Pass Labs sub-forum, because I think there is a need for this information here, and because the idea for a digital attenuator came while building the excellent Iron Pre by Zen Mod.
There seems to be interest in a repository for free information pertaining to digital attenuation systems, in particular the Muses family of chips: 72320 and 72323.
Over the years, there have been a number of attenuators available using the Muses products. Some are commercial, but most were developed in-house by DIYers. Therefore, there is likely to exist quite a lot of knowledge in the community about implementing Muses chips.
If it weren't for generous people like Nelson Pass, Wayne Colburn, Zen Mod, Mark Johnson, XRK, 6L6, AKSA, Salas, and many others, our DIY efforts would have looked very different. And since this forum is called diyAudio, we should embrace the culture of sharing. So, in the spirit of DIY, I encourage everyone who can contribute, to share information about digital attenuation, no matter how small.
In this thread we can collaborate and share information for building our own Muses attenuators. Feel free to share your microcontroller code, libraries, schematics, tips, experiences, etc. as well as questions.
I’ll kick off by listing an Arduino library for the Muses72320 by Christoffer Hjalmarsson: github.com/qhris/Muses72320
Muses72320 datasheet
Muses72323 datasheet
Arduino libraries & code (generously supplied by @Nikon1975) - added 23 Sep 2023
Muses72320 Library
Muses72323 Library
Arduino code (full preamp code, including Muses72323) - added 26 Sep 2023
Arduino code for Muses72323 (Muses72323 code only. It compiles, but not tested)
Muses 72323 library for calculating the 16-bit address by @d00dz1
(Also see this thread for more information)
ESP32 code
Muses72320 on ESP
Library for Muses72323 using Soft-SPI as well as Hard-SPI by jpk73 - added 4 May 2024
SSOP32 adapter board. Mouser# 854-AB-SOIC32/SSOP
Muses72320 Library
Muses72323 Library
ESP32 code
Muses72320 on ESP
Verry happy with the Muses 72323 inside my preamp! based on Meldano’s circuit and microcontroller.
https://www.diyaudio.com/community/...d-state-pics-here.96192/page-368#post-7159684
Wow, very neat build. Well done!
It's great to hear that the Meldano boards are working well. Is there some kind of display to show the volume?
If it's still available, the Meldano attenuators are certainly good options for Europeans. It's a bit out of the way for me and therefore, difficult and costly to import. Well, in my case, most countries are difficult to get stuff from. That's one of the reasons I'm into DIY. But I have to admit that I love it.
Dank je wel. (I have fond memories of visiting Bokrijk)
I'm going to
I've since noticed (in the PDF) that @meldano uses STM32 MCUs. That's interesting. The added power, speed and memory of Cortex and similar processors makes it possible to drive decent displays.
There is a lot to be said for Arduino, but it's unfortunately not powerful enough to drive anything but the most basic displays, hence the crude fonts.
The system that I'm busy working on uses an ESP32 together with a TFT LCD screen. The ESP32 has enough memory and speed to use any TrueType font and display nice, smooth characters. I would take a font file from my Windows computer and convert it into a format that can be used with the display. Easy. I can document the process if anyone wants to know how to do it.
Which microcontroller?
Hopefully in time, there will be enough information here to enable anyone with a basic knowledge of development boards (microprocessors), like Arduino, Teensy, ESP32, etc. to build and program their own digital attenuator - and to their own taste. Whether that includes a nice display or not. The beauty of doing it yourself is that you're in control (pun intended) and can make the attenuator as basic or as feature-rich as you want.
Note: From time to time, I'll update post #1 with information and links to important information. So, check back often.
plenty of material to start, who's willing to
https://www.google.com/search?hl=en...itesearch=&as_occt=any&as_filetype=&tbs=#ip=1
me being familiar with just Arduino, that is what I did type in search
I'm not Wayne, able to think in all machine languages![clown :clown: :clown:](https://files.diyaudio.com/forums/images/smilies/clown.gif)
The Muses chips are really tiny with only 0.65mm pin spacing and it's SMD, not through-hole. This undoubtedly discourages probably most people from experimenting and making boards for the Muses. One needs to be sure that your circuit works before committing a design to a fab house, and the surest way is to build the circuit on breadboard first.
There is a way around that hurdle, in the form of an adapter board. Mouser# 854-AB-SOIC32/SSOP
Here is my Muses72032 chip soldered to such an adapter board, ready to be plugged into a breadboard.
This one is linear analog pot digitaly controled, uses I2C & one gpio, have 8 steps but can be redesigned to 256 step log pot : )
u19 is to keep status of the pot until mcu is alive, and also to prevent clicks and pops, in our case I'm used u19 for that thing in lin pot project but can be removed in log pot configuration. Vertical mount pcb.
Pcb above is mono version, earlier I have not used any relay, used only MAX ic but I was not satisfied with sound 100%, later figured out in d.s. that MAX have 90db thd and decided to add relays. For 256 step (see link in earlier post) you need only 8 relays, speaking about mono configuration. Pcb is small 50x30, verticaly mounted use small area, that's my next project : ) Max ic can be replaced with an stm8 3x3mm programed in i2c slave mode with programed logic for 256 steps for example... I'm expecting good sound using this type of analog attenuator in my revised project! Concretly I have configured it as a lin pot for tone control, 8 steps is good enought for me for tone control. I am thinked to use ts5a or some even better but definitelly the good pot must be fully analog for best result so relays and resistors in my opinion is the best for this type of pot.
for SE iteration, regular two section relays are good for 2 channels
But would not allow for balance control. Like a dual-gang pot.
one relay group covers 2 phases or two channels
if bal, you need to double number of relays
how you're to control 2 groups and make balance control - if you're able to make code for simplest, adding function or two is trivial
anyhow- decide - is this MUSE thread, or whatever as long it works proper?
- Digital Control of Attenuation – Repository for DIY
