Did a discharge capacity test on the battery. It still had 2.3Ah (38% capacity) left. I find that pretty impressive and way better than I expected.
Yes very impressive.
At the moment I power mine with latest generation 4ah 20v Tool Battery for testing purposes. Very convenient to recharge and swap out. Only minor audible difference to linear supply.
The car battery for a month with 6-7 hours of daily listening subsides to 12.5V. Configuration 2.1.
Modified https://www.aliexpress.com/item/1005003472910959.htmlMy unit does not work below 14v.
What brand do you use?
Strange, that bridge going to pin 31.@ domician: IMHO, low quality; bad solder joints...
Nice find. Double MA12070.
Would you post a pic of the internals once you get it?
https://www.diyaudio.com/community/...mp-to-get-from-aliexpress.379676/post-7480882
Sorry I forgot that and have not opened it.Thanks
It sounds good, pretty much the same as Topping Pa3s.
But I know there was some discussion about uneven volume pot with Topping.
But an A-B test confirm that it's not even with Topping but O-Noorus it's right with full volume.
Anyway I got back to TPA3255 with the new 3e audio boards.
Sounds very good!
Same, better, 3D sound as MA12070.
BUT I use the O-Noorus at HF in my two-way active.
Very good combination!Never had better sound!
which what speakers do you prefer the MA?I had several TPA3255 and prefer MA12070.
Anything that sounds good...which what speakers do you prefer the MA?
ah interesting, I thought you were going to say anything that's not low sensitivity.Anything that sounds good...
Then you knowed the answer your self.
Well I was hoping you'd provide details - like what db/1w rated speakers you're using - to get a better understanding of the amp's ability/sound-quality.
My Purifi have 88.7dB and it's just to little for MA12070 I just heard when I bought the new TPA3255.
So maybe 90dB could be a good start.
thanks for the info. Yeah, not a problem for me as the two speakers I have are 93db and 96db.
there is some new board with inbuild MCU
https://www.aliexpress.com/item/100...5481ed962!12000035374345665!rec!UA!141635678!
- Class D
- Infineon MA12070 Class D
