I kinda ‘fudged’ the exit in the sim ?? Any ideas/opinions Before it gets wired up and plays?
My buddy built/rendered this after we looked around in HR for something fun .
Looks like a bass reflex to me, does not look like the port slot covers the cone at all.I kinda ‘fudged’ the exit in the sim ?? Any ideas/opinions Before it gets wired up and plays?
I'd probably have wrapped the port in an "L" to the back of the cabinet to lower the Fb, cabin gain and voice coil inductance will probably make for a downward slope from 40Hz to 100 Hz as it is.
Big surround on that driver, what's the make and model?
2.5 ohms at Fb, that's low for a 4 ohm, and high for a 2 ohm, do they call it a 3 ohm driver?
Any frequency response measurements?
It’s looks just like the slightly underdamped sim …. A little bit of a ‘fart box’. (He used an ‘spl meter’ and a series of closely group test tones )
You guys take the DIY hobby to the CSI tv show level!! 😜
So after the thiele.small forensics ..what was the outcome?
Im very curious about the fr in the car without eq. ..Or the eq settings to make it flat.
Cheers!
Cheers!
Hope this works
Like the equations you share for the upper and lower mass corners 🙏🏻.It's rolling off the HF if that's what you mean.....
- Subwoofers
- 8” car audio tapped pipe
