Good afternoon, could someone tell me where I could get the vu meter for a Pass Labs x250. Thank you, greetings from Argentina.
No. I thought about getting the spare part and changing it. I am from Argentina.Have you tried Pass Labs?
Zen has a point. Things are never simple...
I would see where the meter gets it's signal from and confirm that it is getting everything it needs to operate. Maybe try measuring the voltage from + to gnd then - to gnd and see what the difference is.
Again, probably something that Pass Labs can help with.
The meter in one of my X250s suddenly quit and it turned out to be a broken wire going to the movement. It was an easy fix and didn't require a new part.
the cables are fine. I took it out and it is damaged. I need the spare part to change it. thank youThe meter in one of my X250s suddenly quit and it turned out to be a broken wire going to the movement. It was an easy fix and didn't require a new part.
And where do you think you might get spare parts for a Pass Labs product ?
Pass Labs that make these amplifier sure won't have one or two (hundred) spare ones they could sell you.
Or would they ?
Maybe you'd better ask them just to make sure.
Or would they ?
How is the meter damaged? Normal damage is a bent pointer. That can usually be repaired. In a true VU meter there is a copper oxide bridge rectifier that can fail. An actual open meter winding is rare and probably cannot be fixed.
However if the meter winding is open that indicates something else is also wrong.
Best approach is to contact kent@passlabs.com.
Often it's just bugs or cobwebs in the meter movement.
Thank you very much Nelson. They already contacted me and we are arranging for them to send me a template.
- Pass X250 broken VU meter
