Hi
in your opinion, what kind of neon lamps can be used as a substitute for the Geiger lamp?
Heard about a solar panel that can be replaced?
Why not simply buy a proper SI-22G (СИ-22Г) Geiger tube from ebay? They are not expensive.
https://www.ebay.com/itm/256082603735
And you'll be supporting a Ukraine business!
NE-2s work, you just have to bis them just below the strike level
with a 1 to 10 meg resistor.This varies bulb to bulb. You won't be able to calibrate it
to anything though.
You could look here.
https://fusor.net/board/viewtopic.php?t=5331
to anything though.
A number of devices can detect radiations (ion chambers, semiconductors, etc.), but they all have their peculiarities, and none match the characteristics of GM tubes.
I don't mean they are better or worse, they differ in their response, the type and energy of the particles detected, etc.
I have built a GM detector and an ion chamber one; I still have to build one based on a photodiode/solar cell
Thanks broWhy not simply buy a proper SI-22G (СИ-22Г) Geiger tube from ebay? They are not expensive.
the Geiger tube receives the radiation in a space in the form of a cylinder
I wanted it to be in the form of a plate like a solar panel.
Thank you for taking the time to answer my question🌿NE-2s work, you just have to bis them just below the strike level
to anything though.
I made it with BPW34 photodiode, it works but not accurate💁♂️
I made one last month with 2 x BPW34.
Without a scope and a radiation source , it is hard to say if it works well.
I made it with BPW34 photodiode, it works but not accurate💁♂️A number of devices can detect radiations (ion chambers, semiconductors, etc.), but they all have their peculiarities, and none match the characteristics of GM tubes.
petromax lamp mantle!I made one last month with 2 x BPW34.
Without a scope and a radiation source , it is hard to say if it works well.View attachment 1215106
^ I wouldn't know where to get it , nor do I want thorium near me.
Made it to test those glowing light switches and to see if floor tiles are radioactive , but it seems lost in background radiation.
Also measuring banana's with some Japanses radiation .Taiwan and China are not that far from me , when things heat up and the wind is blowing my way.....
A possible source is an object made from "vaseline glass": it is transparent, but has a tinge of fluorescent green due to the presence of small quantities of uranium salts:
These objects were popular end 19th century to mid 20th.
Another option is uranium-glazed pottery: they have a bright orange color, and were popular in the sixties:
Photographic lenses for semi-accurate calibration. Until now, I only knew that the venerable and excellent Minolta Rokkor 28mm/2.5 had a thorium containing optical system.
Those radiations are very mild! good luck🌺^ I wouldn't know where to get it , nor do I want thorium near me.
It was very interesting, I didn't know that radioactive material is used in the lens!Photographic lenses for semi-accurate calibration. Until now, I only knew that the venerable and excellent Minolta Rokkor 28mm/2.5 had a thorium containing optical system.
The mentioned filaments are slightly radioactive, I don't know about the operation of your lampDoes a thoriated filament in an 811A work to test a geiger counter? I have one I should test.
- Design & Build
- Parts
- alternative to the Geiger tube
