DAC AD1862: Almost THT, I2S input, NOS, R-2R
Miro's DC offset protection board in action for my DC coupled preamp. Thank you @miro1360
I've noticed that I've reversed the connections on pins 1 and 2, I'm using pin 1 for the negative power supply and pin 2 for connecting the NR capacitor, are those pins internally shorted and are the same, or should I do as stated in the datasheet for the best performance?
