DAC AD1862: Almost THT, I2S input, NOS, R-2R
L7805CV is not LDO regulator ,so for 5V on the output should have 6,5V on the input , not so good for batteries
LDO would be much better, my choice would be ADP7118 and ADP7128
Great observation, since these batteries are rated at 8.4 V nominal, they typically will output between about 9.5 V (fully charged) and about 7.5-8V (on low charge), so if I keep an eye on them and check their voltage regularly there should be no problem, this is only a prototype, on the next version (if I use batteries) maybe I will include a low battery indicator and perhaps also a shutdown feature, to turn off the device when the voltage is too low for operation.
Just pray for zero tantalum explosion 😁
I usually don't use tantalum capacitors, so I have never seen one explode, I hope that I will continue this way. 🤞
I have actually exploded one small electrolytic capacitor (10 uF or so) by reversing it's polarity, but it only popped on the underside and some electrolyte came out.
One colleague of the faculty had 2nd degree burns on his arm due to an exploding capacitor, it was an SMD power supply reservoir capacitor included on a Spartan 3E FPGA development kit. Presumably it was a cheap capacitor affected by the "plague" (i. e. incorrect electrolyte formulation).
Reactions: miro1360
It appears to work if I connect the batteries by this order:
1st -> -12 V analog supply (-18 V battery tap)
2nd -> +12 V analog supply (+18 V battery tap)
3rd -> +5 V digital supply (+9 V battery tap)
4th -> -5 V digital supply (-9 V battery tap)
I don't know why, though 😕
A post is missing between #7,146 and #7,147, maybe the post didn't went thru because I was offline.
Even with the LED and resistor, the +5 V regulator won't work, only if I connect the batteries in the order I've mentioned in the last post. I'm not sure if it's the regulator or something to do with the AD1862s, but the voltage at the +Vd pins and at the +5 V regulator is always about -0.7 V when the power supplies fail, and about 4.95 V when it's working.
Once the power supply it's ok everything works fine. 😁
This setup AD1862+AD811 is the best I've listened so far, it's odd, but everything digital that I've listened in my life appear to be much less natural sounding. This one sounds like a very well recorded/printed vinyl record, it doesn't seem digital at all. The soundstage is also great, giving the sensation of actually being there. Every instrument seems to be rendered almost to perfection.😆
The AD1866s sounds good and the AD1851J+LM6171 holds currently the second place in the DAC prototypes that I've made so far, but this is in another level. 🙃
Reactions: miro1360
Hmmm. Then it very well could be the faulty regulator. If you can, order onsemi 7805, it's quite cheap. This way we can narrow it down to batteries if it shows the same symptoms. The ad chip itself shouldn't be at fault here as you have a load on the regulator right in front of it.
Reactions: miro1360
For 78XX, 79XX, LM317/337 and similar, at least 4V input/output differential voltage is recommended. It should be taken into account that sometimes there may be a voltage drop in the network, and ripple voltage is also involved. I usually practice 5-6V differences, and it's not bad to put an initial load on the regulator of some 10mA to make it work properly. For the LDO, 2-3V is enough to work safely, although again there is always a possible voltage drop and ripple voltage.
Also it usually provides better psrr if voltage is above minimum vin. Also on discrete regulators like sparkos one, states min +2v vin, but he measures at +5vin for datasheet and specs he wrote in 😉 But it seems not to be the case here as 7905 one works proper.
Looks like some protection in the regulator is kicking in. They have overcurrent and thermal protection. Check all wires, voltages in front and behind the regulator, regulator heating, and if everything is fine, replace the regulator.
And frankly, the AD1862 deserves slightly better regulators than the 78/79XX. 🙄
Everything seems fine, when the regulator fails, it does not overheat at all, it is as cold as ice 😅
I don't understand why the regulator works fine when I connect first the +9 V and then the -9 V, if this procedure solves the problem, should I replace the regulator anyway?
It's cheap to replace it. If it continues like this after the replacement, then there is a more serious problem. You use batteries for power, I don't have much experience with that. Do you have a schematic of that connection, how is it all grounded?
I've found in my stock a Fairchild LM7805AC, so I promptly replaced the L7805CV. 😁
Now the +5 V is always stable and never seems to fail at startup, the LED always shines, I can power up in any sequence, the only thing that I must pay attention is that -Vs (the -12 V supply) must be applied first, like is mentioned at the AD1862s datasheet.
I thought ST and DigiKey were reliable brands, maybe I was wrong 😡
Do you think I can ask for a refund?
Now I only have one ST regulator in my setup, an L7912ACV (high grade, I guess), the two others are from ON Semi, MC7905B and MC7812B.
Great!
Do note that even the best of brands can have a number % of devices failures, it is a series production after all and not each and any component goes trough qa, but rather as several random specimen from a batch. ST has been good to me, so no need to blame it as a whole 🙂
Yes you can always go trough rma, after all you received a faulty component. Not so sure if it's worth the time for a <1$ component 🙂
Reactions: danny92 and hirscwi
Yes, you're right, I also have some ST components that are working reliably, some for a long time.
Before replacing the L7805 with the LM7805, I've tried to replace it by another L7805 from the same tube and it also failed. It seems like this batch has some problems with the protection circuitry, that seems to be overreacting and shutting down the regulator for apparently no reason, the batteries are fine, with an output voltage over 9 V, I don't know if the -0.7 V come from the regulator output or from some protection inside the AD1862s.
I have a L7805 from this batch powering a AD1851J + LM6171 prototype and it is working reliably, so maybe the protection only kicks in under certain circumstances which I don't know exactly which.
... I can power up in any sequence, the only thing that I must pay attention is that -Vs (the -12 V supply) must be applied first, like is mentioned at the AD1862s datasheet. ...
AD1862 has not specified power up sequences.
"... the limitation that –VL may not be more negative than –VS." it is meant for normal operation. Inside the dac are switches with the ability to distinguish TTL or CMOS logic and I think it is specified for that reason (for normal operation, not as a limitation against chip damage or bad power-up) 🙂
You can study all that from AD1862 related patents: U.S. Patent Numbers: 4,349,811; 4,857,862; 4,855,618; 3,961,326; 4,141,004; 4,902,959.
Reactions: danny92
