Chinese EL34/6SN7GT SE Unusual Topology
After removing the 470uf the results were an improvement in THD (as expected)..
1kHz, 3.15w with 470uf = 3.14%, without 470uf = 1.6%
1kHz 5w with 470uf = 4.8%, without 470u = 2.6%
10kHz, 3.15w with 470uf = 3%, without 470uf = 1.98%
10kHz 5w with 470uf = 4.5%, without 470u = 3.3%
I am somewhat amazed at how these two changes have benefitted the sound quality.
There is greater clarity from all instruments but with no listening fatigue - overall a very pleasant sound. (mid/woofer driven by my Krell Class A clone)
LR8 CCS next.
Now fitted a 10m45 to one channel and ran the tests again. The spot frequency measurements below were done with Picoscope (REW's generator)
The fft was done with REW which shows a loss of about 1db at 20Khz which is not relevant.
1kHz, 3.15w with 470uf = 3.14%, without 470uf = 1.6% with 10m45 = 1%
1kHz 5w with 470uf = 4.8%, without 470u = 2.6% with 10m45 = 2.1%
10kHz, 3.15w with 470uf = 3%, without 470uf = 1.98% with 10m45 = 1.9%
10kHz 5w with 470uf = 4.5%, without 470u = 3.3% with 10m45 = 4.12%
See schematic for voltages - blue with the 10m45 fitted. C1 and R3 were removed.
I think the results are pretty good but no listening tests until the other channel has been converted.
Also, I can to increase the feedback to lower the gain by -6db.
Reactions: jcalvarez
Changed Rfb (R12) from 2k to1k and now recorded 0.73% at 1KHz and 3.1watts, 1.65% at 5watts. Gain is now the same as the unmodded chnnel - 0.7v for 3.1w and ~ .9v for 5w so call it 1v RMS for max output with < 5% THD (5.5w)
At 10K, 1.8% at 3.15w and 4.7% at 5w.
So a further improvement except for 10kHz 5watts.
