0-44VAC toroidal transformer - ideas?
Many class D amp circuits / boards run off a single rail DC power supply and that transformer would make about 62V DC unregulated.
If you can get another identical transformer, you can build a dual power supply for a class AB amp in the 150-200W / 8 ohm range.
One transformer for the positive rail and the other for the negative rail. I built an amp this way in the 90's which I still use.
Reactions: sparkle
People love their direct connect speaker burners don't they. I don't: my speakers cost 8 times what my amp did. A new bass driver would be $250. A new tweeter would be $200.
)44 * 1.4) - 1.4 = 60.2 v. Just about perfect for a first generatioin solid state class AB amp like a Armstrong 621 or a dynaco ST120 . The speaker capacitor prevents burning the speaker if a solder joint pops loose (As my diy bike battery charger did today).
With better sound, the Apex AX6. https://www.diyaudio.com/forums/solid-state/236256-retro-amp-50w-single-supply-42.html
I originally improved the poor cold low power idle bias current ST120 with the auxillary 7 transistor djoffe closed loop bias control circuit. However, an AX6 does the job with 6 transistors total. Same 2 output transistors as ST120, remote from the driver board on the heat sink. Much better sound. I run mine at 69 v for 72 watt performance over 5 seconds. 60 v would be more a 50 w amp.
Cap coupled singleton-input amps can sound surprisingly good. They can produce “farting” sounds if driven into heavy clipping with sub bass, but that is outside the range of hi-fi usage. The fix for that is to use a 30,000 uF output cap, a somewhat smaller main reservoir cap, and intentionally roll off the sub-audio frequency gain with the input coupling and feedback caps. With normal music and light or no clipping you can’t really tell it from a DC coupled amp, even with modest caps if you use new ones.
Those singleton input amps can sound a lot better than the usual diff pair input if the pair is mismatched or the currents out of balance.
would you be kind to share the schematic of how you built that power supply with two transformers... thank you
Each polarity: secondary - FWB rectifier - cap
The two supplies connected in series with the CT grounded.
An example:
Reactions: sparkle
As usual, keep the first filter capacitor directly connected to the rectifier, and then bring out the pair of leads
from each capacitor's terminals to the load. This avoids having IR drop in the wiring that has high current pulses.
Reactions: sparkle
