Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
I do have an issue…when I have a source connected and volume maxed there is some hum. Ground loop, right?
No source connected = no hum
I can see that you have two/three different ground connections to chassis?
One for the mains and one for each PCB?
I think better to have just one chassis screw and connect using two wires from PCBs to same screw......but not sure that it will cure your hum.
I have no hum in my SE version 🙂
I am always impressed by people who can lay out neat wiring and plumbing. Wow.
I’ve been working my SE into a scavenged chassis. I was able to do a quick signal test this morning and it amplifies.
Is that measured under load? It's common for transformers to measure higher than the nominal voltage on the bench, with no load.
Just to confirm - measured with no load. I was just hesitant to connect it (to my precious IP board) with measurements that differs so much from the specs. Also hesitant to mention that in my 7 years of diy this is my first time using and connecting a toroid. But all is well so far. Thanks for all the support.
Reactions: tubesguy
