DAC AD1862: Almost THT, I2S input, NOS, R-2R
I soldered the AD797 I/V PCBs.
I don't know that this Civ of AD797 I/V is optional like the Civ of miro's AD1862 DAC.
Can I solder a jumper wire instead of Riv of miro's AD1862 DAC for AD797 I/V?
AD1862, I2SoverUSB v.III - not flipped, 20-Bit uf.l connectors
I2SoverUSB not flipped (pin-headers installed on the bottom side on I2SoverUSB) ... the heatsink and USB connector are on the TOP 🙂
Hi Miro,
Using "the not flipped PCB version" and the I2SoverUSB v.III powered-up itself. If only H3-9 to H3-16 connected btw both boards, no-touch on SJ1, SJ2 and SJ3, is it correct?
@happylistening "I2SoverUSB v.III powered-up itself" -- I assume you mean powered by a USB cable:
SJ1 - close
SJ2 - close
SJ3 - open
Jumper J4 on I2SoverUSB board - close
If you mean powering by itself as powering from an external power supply (not with USB cable from intergrated regulator on I2SoverUSB board), than as you typed: SJ1, SJ2 and SJ3 is open (no-touch), just the jumper on J4 and the respective power supply for I2SoverUSB board.
Reactions: happylistening
Quick question before starting on the shunts. What current draw do you see from the AD1862 and the shift registers? I found one post mentioning the 5v shift registers draw ~25ma and each ad1862 seems to consume ~15ma judging from the spec sheet.
Cheers -
