OMA - MONARCH Speakers DIY
Hello dear friend this is my first post and Greetings from Sakartvelo i think you are doing great job helping each other also shearing helpful information so I also need your help.
I saw oswaldsmillaudio/monarch series speaker and i fall in love so i don`t have 300 000 $ but i must have this speakers at home.
i am good at woodworking and i can build exact same cabinet by myself with custom dimensions, but i could not decide what drivers to use in this build so please help. also my budget is pretty limited max 400$ per speaker (plus minus 50$) also room dimensions for this peace of art is 26 feet X 26 feet X 19 feet (ceiling high ) i know that for 400$ i cant do much to fill this room with crystal clear sound but this design need some good sound, ( also i thought to build World's Second Best Speakers! with pair of full rage tang band w8-1772 speakers and attach wings and design to his built cabinet ) but horn on OMA Monarch speakers should be 3 way horn driver sorry for my English
As far as I know, it's 'just' a pair of 15in woofers in a triangular shaped sealed or vented box with extended front wings to lower the step-loss frequency right down to the point where room gain / modes dominate, partnered with their own compression mid-tweet and horn. So basically -pick whatever quality 15in woofers you can afford that suit your preference for sealed or vented loading, pick whatever quality compression mid-horn you favour that can get down to at least 800Hz, and likewise the compression driver. Without knowing your budget it's hard to make any useful recommendations though.
Reactions: GM
If you pick one of the "ready to print" horns that are presented as STL files in the https://www.diyaudio.com/community/threads/acoustic-horn-design-the-easy-way-ath4.338806/ thread, chances are that the results are even better than the original OMA horn.
Something like this: https://www.diyaudio.com/community/...he-easy-way-ath4.338806/page-394#post-6760060 might work.
st280e-4-png.976425
That's the 280E,
The 260 is the default example from that thread but loads the CD a bit less:
https://at-horns.eu/ST260.html
But it's a free tool and with a bit of elbow grease, with the new version you can even make a petal horn but with smooth directivity control as a plus.
Just use more petals to come close to the OMA design. Printable in pieces as many users have demonstrated.
Reactions: Scottmoose and GM
can you recommend any 15 inch subwoofer ,compression mid-horn and compression driver in 400$ price range?> i haven`t heard any speaker from parts express ( i want full range frequency response ) thanks for reply
I want to know exact parts compatible with each other sub+mid+horn
Maybe consider finding the 1.5" throat horn with the shape you like then asked the manufacture if they have any plans to mate it to a 15 and CD or something a DIYer completed. Otherwise you'll have to design an original crossover which isn't so hard anymore with current low priced and freeware tools.
Hello Forum,
Just a quick update on my speaker build—I’ve finally started working on it and wanted to share my progress with you.
🔧 Driver Selection:
Woofer: Dayton Audio DC300-8 (12", 8Ω)
Midrange: Dayton Audio MB620-8 (6", 8Ω)
Tweeter: Eminence ASD1001B compression driver with B-52 PHRN-N01 waveguide (8Ω)
📏 Enclosure Details:
I designed the box using WinISD. Here are the specs:
External Dimensions: 89 cm (H) × 40 cm (W) × 40 cm (D)
Net Internal Volume: 92.45 L (3.26 cu. ft.)
Slot Port:
Height: 3 cm
Width: 36.5 cm
Depth: 34 cm
Port Area: 263 cm²
Tuning Frequency: ~30 Hz
🎛️ Crossover:
I’ve measured the drivers independently and calculated crossover schematic that I followed, but I'm unsure how accurate or well-matched it is.
also, this are the pics from my build:
this is measurement using Denon AVR Measurement microphone ( i know it is not suitable but i have destroyed my dayton audio measurement microphone while testing so i had no choice)
this is REW data :
i want to point out that my room is not near perfect it is 8 meters wide and 8 meters long with ceiling at 7 meters high so i get no Bass i was looking for i want bass down to 30 herz please help how to achieve it /. i have asked ChatGPT and it suggested to widen port to 6.5 cm to get this bass but i think my room is issue so i will bring speakers to different room and test after 1 week
If you have any feedback or suggestions on the crossover design or box tuning, I’d love to hear your thoughts!
