Very good high-speed rectifier filter design, how to see only PCB diagram, please add circuit diagram, thank you!
Muting with a resistor/FET is risky, the non-linear capacitance it presents when un-muted may cause distortion, that depending on the impedance at that point.
A relay is risk-free.
Jan
Jan
Thanks for the reminder, here is also an attempt to get a high signal-to-noise ratioMuting with a resistor/FET is risky, the non-linear capacitance it presents when un-muted may cause distortion, that depending on the impedance at that point.
Jan
- MOS Amplifier
