Selling off parts to fund some projects
These are SMD solid state relays, i removed them from their original packaging some years ago. LH1540 Series SPST 350 V 120 mA 1 Form A Surface Mount Solid-State Relay
Im asking 30 cents each because they are out of their antistatic packaging. Ideal if you want to design something for very small mains current. Price at 10.000 PC is more than 2 euro each!
Datasheet is attached, more than 100 available.
  • lh1540aa.pdf
    lh1540aa.pdf
I got some of these Tin foil 13nF capacitors remaining, they where manufactured by Fribourg for the Belgian postal service if im not mistaken.
I have no idea about tolerance or working voltage, I assume at least 2.5% tol and 63V working voltage. Nice if you are designing RIAA/FILTER stages.
€0.15 each, 80 available.
V4LVE
330uF Kemet ALC40A331DD400 caps 330uF 400VDC 8000H @105C
Produced in early 2015, should still be fine.
SNAP-IN 35MM DIAMETER. Height 42mm.
Digi-Key price, €9.89 in singles ex VAT.
Asking €2.50 each, 20 available.
AUY10 Germanium PNP low power high bandwith TO3 transistors. Could make fun output devices for a headphone amplifier or drivers.
The ones i have are all from the same batch.
I should have over twenty of these remaining. Asking €0.75 each.
2 Pieces of 120V primary, sec : 2x18V 120VA toroidal transformers, German made, nice quality.
60 Euro including shipping to the USA. They weight 3KG with packaging, and the shipping label allows for shipping an additional 2Kg off stuff.
V4LVE
These are 50x90mm capacitor multiplier boards, with a fuse. A bleeder resistor+Led and two resistor footprints.
Asking €2 each, 15 available.
