Is VFet an internet influencer thing that makes no sense at all?
Looks something is going on here.
But one thing I don't understand is that If an amp is not linear sine wave after amplification will be distorted. How an amp without a triode or vfet achieve linear?
Three modes of correction exits (that's all folks, we've to cope with it):
  • backwards Euler (always to late), modern politics, current technology, diy approach
  • forwards Euler (future telling, aka Merlin peeking), predict, labour, mastering, prophecy
  • moving average (the best sofar, operational achievable) learn, improve, goal, zeal... hope (?)
This is forward, hence the convex transfer.
Any modern audio amplifier relies on (local or overall) feedback.
The vacuum triode already prooved to be the golden sweet spot, but a better world loomed (the 'now').
Its very shortcoming is the key.
Well, there it is...
Referring to #140, let's say with supply rails of +/- 24Vdc:
What readily available complementary Nch/Pch enhencement mosfet's are recommended as output devices?
And what readily available complementary Nch/Pch enhencement mosfet's are recommended as input devices?
Just mediocre types will suffice, datasheets are welcome to determine the supporting (E6/E12 series) resistors for the qubes.
(I do not know many mosfets as these came available after I finished my study years ago, and I'm not used to them.)
Thanks in advance.
The aim was to recreate triodes with semi's, but now available in N- and P-version (vacuum is only N).
J-fets, mos-fet's, bjt's of any kind, resistors only (20% is good enough), no strange/rare other components.
Suitable for low-, medium- and high-power semi's.
Compounds can be made with jfet+bjt, jfet+mos, mos+mos, mos+bjt, bjt+bjt, bjt+mos.
Notice the even distance of the curves of the compound.
Sweep is 10V, current is 6mA (=Idss): ouput resistance ('Ri')≈4kΩ, S≈6mA/V, µ≈10.
I have to make some leads, next are the 2N5461 (p-ch jfet) and a BC560C, then the 2N7000-twice compound.
Reactions: sp33ls
