Class D Amp Photo Gallery
500W@4Ohm AMP module.
Thanks!
Self-oscillating amplifier based on UcD technology with combined feedback and ultra-deep loop gain. feedback in the audio band after the output filter.
An IRS20957 with an additional discrete transistor stage is used as the output HB driver. Modulator on TL3116+ OPA1602. The modulator uses a 2nd order pre-filter, and a 3rd order "integrator".
For the convenience of use the board is equipped with two-level power regulators for the operational amplifiers and a step-down converter for the driver IRS20957, so no additional power supply is needed. The instrumental preamplifier on the OPA1602 with universal DIF/SE input is also on the board.
Please note that the size of the case is 25 by 18 cm. The maximum power is 600 watts. 300 watts per channel 4 ohms. Try to reduce the size of the case without resorting to a separate placement of the power supply
Reactions: stewin and Sous
I re-housed my Orchard Audio Starkrimson Ultra amplifier into a pair of monoblocks. I upgraded to Micro Audio power supplies and custom built enclosures with the help of some Galaxy side panels. I mounted the PCBs to pieces of aluminum and mounted those to the galaxy plates via the hardware channels. I did the same with the foot plates. I incorporated plexi to ensure maximum transparency (lol).
Great job.
Reactions: poseidonsvoice
Class D amp back in the main system. Giving its Class A brothers a break in the hot summer. This is a pair of @abraxalito’s transformer input TDA8932 MonoAmps in an old chassis. They sound beautiful.
