What’s On the Bench Tonight (OBT)
10-channel amp/DSP/WiFi for the Return of the Marthas. Lots of wiring in progress, with lots of software to follow.
Reactions: ernperkins
TB W8-2314’s are mounted in the TL proto cabinets. Laminated a layer of XPS foam board to the baffle to simulate flush mounting the drivers. XO parts arriving any day now…….🤗
TB TL Update:
XO's were assembled on the bench and connected to speakers earlier this week.
I've got approx. 20hrs of run time so far. Wow, I'm super impressed with this speaker package! Deep bass, crystal clear vocals and just the right amount of sparkle, very balanced sound overall.
Thank you X, you did a fantastic job whipping up an XO for the W8-2314 and suggesting to drop it into the FAST TL cabinet!! I hope the availability of this driver will increase so more people can build this speaker, its a keeper👍
Reactions: Plott and xrk971
What is on the bench indeed, capable of 180Vpp into 5ohms?! Not very often have I had to use 50V/div on my o-scope. The dummy load needed to be fan cooled that’s for sure.
You do the math. 🙂
Meanwhile, on the other bench, one meant specifically for pushing paper, I just cleaned up a room used for storage for past 3 years and turned it into a paper pushing bench, complete with Vanguard speakers and a T9 hybrid tube amp with USB DAC.
Paperwork has never sounded so good!
180Vpp is 63.6Vrms. That’s 809Wrms into 5ohms.
That’s an HP 12c - I think they are still made today. One of the longest running and best selling products from HP (continuous production since 1981). Although now it’s made in China of course. The keyboard still feels fantastic like the old ones.
On my lab bench I have an old (circa 1991) HP32Sii. That’s still my favorite scientific calc. I had to repair the rotted foam rubber cushion that presses against the flexible circuit contact that connects the keyboard buttons.
I wish I bought the HP15C back in college. They are like $700 now, used.
Before grad school, I had one of those clamshell HP-28C’s. It was the first graphing calculator capable of symbolically solving equations. No computer connectivity but computers in those days were not so great. It died at some point around 1990 and so I got the HP-32Sii.
I use the equivalent app on my iphone - it’s a free clone called “Retro 15C” and made with a photograph of keyboard and even the LCD looks accurate.
Here’s a screenshot. Only works in landscape mode. I miss the tactile click on buttons. It even flips over so you can read instructions on back for programs etc.
OTB tonight: an affordable Mechanical Keyboard, which I opened up to work on stabilisers and damping the insides of. Problem: switches soldered to the PCB is what keeps the top plate assembled to the PCB.
Of course, after I put everything back together, including the keycaps, I find out that I forgot to re-solder the spacebar switch. Another issue: too much grease on the right SHIFT key made it stick.
Had to remove all keycaps again, unscrew, open, work on it and re-test before closing it all up again.
You quickly understand why the cool kids are all playing with hot-swappable switch mecha KBs.
Once you've tried a Mecha, you don't want to touch membranes again.
I had one key on an HP laptop go bad - the letter K. I had to buy an entire new keyboard and palmrest, trackpad and speakers (essentially the main laptop chassis) just to pull the good key from it to replace the bad one. They don’t sell single keys. It turned out that the model was just slightly different enough that the key didn’t fit. I ended up sacrificing an extra “ALT” key and renamed it “K” with a sticky label.
Reactions: YashN
