LME49830 Reference Design Amplifier
Too bad the chip has been discontinued. This is a first go FFT of the LME49830 driving 2SK1530/2SJ201. The output devices are closely matched, bias current set to 250mA. I was fortunate to get the original NatSemi EVM boards several years back.
Hi Jackinnj:
I still have some 498xx around. Any schematics/pcb drawing you would like to share?
The design uses the Nat Semi EVM => evaluation module and the "Reference Design" with K1530 and J201 MOSFETs. It's still available as a PDF on the TI website. One board uses the single pole comp, the other uses the dual pole comp.
These EVM's come up for sale occasionally. I think you can make a more compact PCB by simplifying and eliminating a number of the test points on the EVM
The unloaded rails from the Polaris Sumo will deliver +/- 56VDC so with a pair of P and N MOSFETs this should be a very robust amplifier.
I am going to put the original Polaris Sumo PCB's up for sale on Ebay.
Just to note, this series of chips in the Reference Design use the Aavid HS335 heat sink. This has a little clip which holds the chip to the sink. Thermal resistance is 6.3 C/W. I have a few of these left over, but they are also available from the usual suspects.
The easy way to determine PdMax for the thermal resistance is to multiply the absolute supply rail voltages, Vcc + |Vee|, by the quiescent current (which is constant).
You can do both. The Hitachi/Renesas do not require a temperature sensing transistor.
Heck, could also do some boards for the OnSemi Thermal Trak.
I have one amplifier which I rarely use anymore -- based upon the LM4702 (which begat the LME49810,11 and 30). I still have the PCB in Ultiboard. The Nat Semi boards give a few more ideas.
